Discseven's Avatar
'79 930 dies while driving... can instantly restart
Driving and engine quits... tach drops to nothing... think oil & gen light came on but not betting my life on it now---was on highway busy thinking about ops if car did not start. Push clutch in and key the ignition and it started right away. Happened twice during 1.5 hour drive. Same immediate key restart (while rolling) both times. ???
4,000 miles ago... new: alt, ig wires, plugs, coil, dist cap & rotor, forward fuel pump, ground strap.
Karl ~
Current: '80 Silver Targa w /'85 3.2
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver 930. '79 Black 930. '79 Anthracite 930.
Old 12-12-2017, 03:50 AM
T77911S's Avatar
CD and coil are something to consider. BUT, usually when they do this it is due to heat and the car DOES NOT start until they cool off, just something to keep in the back of your mind.
there is a "delayed action" relay that powers the CD unit. this is what keeps the CD on and keeps the engine running after you turn it off. if you can solder I would consider pulling it out and resoldering the joints.
same thing with the over boost relay. try resoldering the joints,
fuel pump relays. could replace them.
I would remove the connector on the rear of the AFM so the pumps will run with the engine off. then when it quits don't touch anything. check the see if the pumps are running.
check the over boost sensor and wiring. try wiggling the wire with it running.
I don't know if power for the CD goes thru the connector on the relay panel in the engine bay or the one at the firewall. probably the relay panel. pull that connector and check the pins. make sure they are tight and clean.
could also be the green wire from the dist to the CD unit. wiggle it with the engine running.
check the sockets on all the relays mentioned. make sure they fit properly.
problems like this suck because you cant fix it if it aint broke and if one of these does fix you may only know because you wont break down again. good thing is there really is not much that will do this.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 12-12-2017, 05:00 AM
I don’t know if the 79s had the Speed relay under the drivers seat like my 86, but I had your exact problem intermittently. One day I hit a huge bump and the car died- pulled the plug off the back of the fuel distributor and with key on had no fuel pumps running... left key on and went wiggling and when my hand touched that relay the pumps kicked on. I cleaned and reseated that and have not had the issue again in years.
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 12-12-2017, 05:53 AM
T77911S's Avatar
nothing under the seat.
Old 12-12-2017, 06:17 AM
Discseven's Avatar
Input is appreciated guys.
Nice hit list T77... I can solder... thanks!
Let you know outcome.
Karl ~
Old 12-12-2017, 08:39 AM
stevie 77 930's Avatar
over boost sensor is easy and cheap to replace. Start there....
2018 GTS
2017 BMW 340I M Sport Package
1977 930 (recently sold)
1976 911S , 1973 1/2 911T, 1972 911E (long gone)
Old 12-12-2017, 10:28 AM
Ken911's Avatar
Sounds like the green wire to me. mine was intermittant and i chased it for a couple years until it was bad enough for me to actually find it. One time it died in traffic and decided to start the moment the tow truck arrived.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 12-12-2017, 10:54 AM
Hi guys ,
I hope this question wont derail the thread , Ive always read about the green wire and always wondered were can this be found in the car . Is it from the distributor ? Connected to were ?
Thanks in advance ,
Tdh888
Old 12-12-2017, 02:15 PM
Discseven's Avatar
Was at ParkHaus today to get Bpads... and looked at pricing for both of those sensors while there. OB sensor is on menu. Gotta sort out totality of what was done 4k miles ago ('15) to narrow diagnosis approach.
I know that tow truck trick---works well sometimes. My distrib to CDI wire 4k ago (below.) Is coax. Forgot exact symtoms--- think it was run sometimes and not at other times... and cut off while running. Don't think it started right away. New green wire is installed. Junctions will be checked.
Old wire junction... clearly on last legs.
Karl ~
Old 12-12-2017, 02:24 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Originally Posted by TDH888 View Post
Hi guys ,
Thanks in advance ,
Tdh888
The wire is connected on one end to the distributor, passes through a wire sleeve bundle, and is connected at the other end to the CDI . . . the inner wire carries the signal from the CDI, and the outer, braided/shielding wire is connected to the CDI common ground terminal.
Old 12-12-2017, 02:35 PM
'76 911S 3.0's Avatar
The tach dropping to nothing immediately indicates something with the ignition/CDI to me
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 12-12-2017, 02:58 PM
Discseven's Avatar
Rawknuckles illustrated...
Condition of green wire junction at distrib is not easily noticed because entry location being at backside of distrib.
If correct... that narrows things down. Am not sure how to test CDI for rare failure.
Karl ~
Old 12-12-2017, 03:37 PM
KinkyKarl, I thought you were selling that bisch, bisch?!?!
Old 12-12-2017, 03:43 PM
Thanks you ,
tdh888
Old 12-12-2017, 03:55 PM
Thanks guys,
tdh888
Old 12-12-2017, 03:58 PM
Discseven's Avatar
RonObisch, yup... still sellin. Hope all's more than well with ya Norflander!)
Karl ~
Last edited by Discseven; 12-13-2017 at 02:55 PM.. Reason: Sales stuff didn't feel right here. Simplified it.
Old 12-13-2017, 12:48 AM
Discseven's Avatar
Pulled fuel tank to recoat. Be a few days messing with this then will dive into diagnosing electrical issue. Will update thread with whatever's found.
Bare metal. Will use Wurth Stone Guard Gray.
Karl ~
Old 12-13-2017, 02:54 PM
Crotchety Old Bastard
RarlyL8's Avatar
This is the beginning of an electrical failure. Isolate and check the parts that can kill power to the ignition. This will include all relays, all fuse fixtures, all associated wiring, and every component of the ignition system. Checking dead paths for resistance can locate a corroded connection or damaged wire, testing strength of voltage on live paths can detect faulty components. Blindly replacing parts gives no assurance that an intermittent problem is fixed. I just went through the same scenario with my 930 after replacing most of the ignition system as normal maintenance. Pretty aggravating to have it leave you stranded after a full tune-up.
Old 12-13-2017, 04:30 PM
T77911S's Avatar
hey brian, you said my WUR has separate adjustable boost and WCP, it does not, when are you going to do something about it. ignoring my PM's is not a solution?
Old 12-14-2017, 04:41 AM
RarlyL8's Avatar
I'm not ignoring anything, send me an EMAIL with your contact info like I asked and we'll get it taken care of. You also need to send it back so we can see what's going on.
Now back to the thread at hand...
Checking everything that can kill the ignition also includes the ignition switch and associated wiring.
Old 12-14-2017, 09:12 AM
