Non User
infraredcalvin's Avatar
Call Brian (Rarlyl8), he will set you up, easily a diy and adjustable setup. I have a singe passenger out with the wastegate drivers side out.i don’t think I have a good sound clip, but I’ll look...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 01-02-2018, 03:19 PM
Crotchety Old Bastard
RarlyL8's Avatar
Thanks for the props guys, appreciate it!
RarlyL8 Motorsports is dedicated solely to the Porsche 930, with exhaust systems being the focus.
If you want a good sound, not just a loud sound, our tuned headers are second to none. The tone is subdued at idle, pleasant tuned tone when cruising, and absolutely screams on the pipe! More Ferrari, less motorboat. Our mufflers offer 3 sound levels, Outlaw (straight pipe), Hooligan (flame tube), and Street (muffled flame tube). Combine with 4 tailpipe configurations to get the look and sound you want. All 3"ID straight through design for max performance. 321 stainless is light weight and tolerates a lot of heat for a long period of time. Our headers and mufflers have been on track cars for years with zero failures.
Here is a sound clip Magnus made some time ago of a Hooligan muffler on his 3.0L 930. Captures the sound pretty accurately.
https://www.youtube.com/watch?v=rAY7lOW1Wyk
Old 01-02-2018, 05:42 PM
Turbo Powered Snow Blower
Brian,
Who is the source for the black heater ducting?
Sent from my iPhone while Driving
Derrick
Old 01-02-2018, 05:57 PM
Originally Posted by kevin930t View Post
This is true.I am currently running B&B headers with heat exchangers and will be placing a order in the next couple weeks for Bryans headers.I am getting excited just thinking about it.Have any one of u swapped your B&B for Bryans headers?
Sent from my SM-N910T using Tapatalk
A ISO/TS16949 certified OE manufacturer of Auto Parts since 2004. Producing fuel line, oil cooler, water outlet/thermostat assembly, coolant water pipes, all kinds of tube/pipes. Website & Page: www.fb.com/021auto
Old 01-02-2018, 06:04 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Deez, you can get the black heater ducting from Aircraft Spruce . . . the black is CAT and/or CEET (both styles are black), and the orange is SCAT - orange is higher temperature rated. BUTT, maybe Brian's is different?
Old 01-02-2018, 06:36 PM
Originally Posted by 93097004xx View Post
I would like to retain a single exhaust.
I do like the look of this exhaust. What did it cost installed?
Installation is the stick point. I probably installed from the turbo & waste gate outs on 5 or six 930s over the years. Depends on the condition of the bolts/studs and if you break any. Probably the least time was 3 hours. Probably a good muffler shop with the right stuff, less. Replacing the complete system well that has the same variables like frozen bolts or studs breaking, a lot longer.
Anthony @ Voitureltd Bayside WI.
Old 01-02-2018, 06:38 PM
RarlyL8's Avatar
Aircraft Spruce & Specialty carry SCAT and SCART tubing. I recommend the aluminum tubing for use with headers as it can touch the pipes without harm and conducts heat better as it warms up with the system.
We have replaced many short tube header systems with our tuned system. We see a 35whp gain on a stock Euro 3.3L engine with short tube headers; our tuned headers show a 50whp gain. Another plus is the properly designed waste gate circuit. The short tube systems use a cheap elephant nose that juts out under the turbo flange at a horrible 90° angle. We take a signal off of each bank at a more shallow angle and merge them for use with a single waste gate. We also have options for dual waste gates. All headers are split plenum so you can use a split volute turbo with dual waste gates for a true divided system.
Old 01-02-2018, 06:47 PM
Originally Posted by Mocker View Post
. The factory header/turbo, in particular are crappola.
The US 76-79 exhaust system especially with the thermo reactors are indeed crappola. The 70s Euro and the US exhaust from 86 onward, not so bad. Just had GHL headers & a Borla passenger out system removed and installed NOS Factory heat exchangers, cross over and J pipe ( I had been hoarding it for about 15 years) with a RarlyL8 passenger out on my 89 930 that previously been on the engine dyno @ 472HP. ( turbo upped to a K28 from a Brumos 934 along with lots of everything else ). Felt the same now as before but a new set of those headers RarlyL8 makes would be even better so those might be next.
Old 01-02-2018, 07:02 PM
Jeff NJ's Avatar
Here is a video I took a couple years ago after I installed RarlyL8 headers (with heater boxes) and hooligan single outlet muffler. I also have a K27HFS, and a TiAl with 1.0 bar spring TK IC and Leask WUR.
I used a gopro with a remote microphone taped to the bumper right over the exhaust to get the most realistic sound I could without all the wind noise.
Turn up the volume! If you have a desktop with a subwoofer sound system, use that to get a good idea of the real sound.
1988 930 Venetian Blue
Old 01-03-2018, 07:28 AM
Old car guy.....
Bucketlist's Avatar
^^^Nice video: Your exhaust off throttle sounds just like my Zork (cis) but under load those Rarlyl8 tuned headers sound really sweet, lot nicer than my old Powerhaus headers.
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car. Sold
Old 01-04-2018, 05:27 AM
Here ya go. https://www.dropbox.com/s/py4y9wi2frxfnxn/File%20Dec%2006%2C%2010%2055%2017%20PM.mov?dl=0
First engine start after FrankenCIS, RarlyL8 headers and hooligan, K27/29 hybrid, Tial 0.8 bar and TK intercooler.
Old 01-04-2018, 08:27 AM
Oh heck yeah...
Old 01-10-2018, 12:47 AM
Alexm930's Avatar
Brian of Rarlyl8 makes IMO one of the best tuned systems available for the 930
Speedlimits are for the guidance of wise-men & the obedience of FOOLS!
Old 01-10-2018, 05:34 AM
puddy's Avatar
I've swapped out B&B headers & muffler for Brian's RarlyL8 headers and hooligan muffler = Amazing difference in sound, performance and quality.
Here is my sample at idle.
https://www.youtube.com/watch?v=52YfqIKIBe0
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 01-10-2018, 07:22 AM
svcetiquette's Avatar
Nice Jeff! That's by far the closest recording to how my '86 with Brian's headers and street muffler sounds, especially at full tilt. I would say the only difference with the street muffler is it takes a slight edge off the "raspy" sound at idle and part throttle. Tradeoff is the turbo whistle is also not as distinctive at idle.
Todd.... '86 930, DC13s, TK I/C, GT-35, Rarlyl8 Headers and Muffler
“The only thing we learn from history is that we learn nothing from history.” ― Georg Wilhelm Friedrich Hegel
Old 01-10-2018, 10:26 AM
Metal Guru
911nut's Avatar
I used this guy (he supplies orange ducting and if you give his the lengths you need, he puts ends on it which are essential for clamping):
Custom Ducts (800)863-2620
Custom Ducts! The source for Aircraft Ducting
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-16-2018, 09:33 AM
16Volt's Avatar
Did Brian make that zork? I have the hooligan dual out but it would be cool to be able to swap to GT3 style zork.....
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 01-16-2018, 09:40 AM
puddy's Avatar
16Volt - That is Brian's (RarlyL8) centre exit hooligan pipe with GT3 style tail pipe. I believe a zork is a short curved pipe directly off the turbo. where as the Hooligan is a muffler body with no packing, bolted to the turbo, then the exit pipe comes off the end of the hooligan pipe, turns 180 degrees then has a short 90 degree turn section. I actually have a dual tip that I may add onto the single pipe and see if it changes the exhaust note at all.
Cheers, Chris
Old 01-16-2018, 12:16 PM
puddy's Avatar
For fun here is an outlaw pipe, in place of the hooligan pipe. The "outlaw" is a straight pipe.
https://www.youtube.com/watch?v=7OYIdpdTjkQ
Its a little louder than the hooligan pipe. For fun, I tried a home made zork pipe before I got Brians outlaw & Hooligan pipe. I found the zork to be quite obnoxious and since I respect most of my neighbours I went with the quieter hooligan option.
Cheers, Chris
Old 01-16-2018, 12:20 PM
