Aftermarket exhaust..
My Y pipe and exhaust are in need of attention. I have fought this partly do to keeping originality and partly do to cost..
So my thought process is what can the world of aftermarket exhaust offer in the way of sound?
My ideal setup would be a exhaust that would look mostly stock from outside mainly the exhaust pipe.
I want to be able to have heat in the cabin.
This may come as a surprise to some of you but I would prefer it to be loud..
I guess if I had to describe a preferred engine note it would be 993 gt2..
I guess what Iím asking for here are pictures and preferably videos of your aftermarket exhaust.
http://9309700485earlyturbo.wordpress.com
Old 01-02-2018, 04:59 AM
I also understand that a the induction system or air box contribute greatly to the sound a exhaust system makes.
I would like to keep my stock air box if possible.
Old 01-02-2018, 05:14 AM
If you want loud, get one of RarlyL8's Hooligan systems. Either a single or a dual outlet is available.
Old 01-02-2018, 06:24 AM
Turbo Powered Snow Blower
I don't know if anything is out there that replaces the stock look for exhaust headers. The doubt the demand is there for anyone to manufacture something like that.
To make the car louder you just need to replace the muffler assembly with something louder. As mentioned above Brian at RarlyL8 has four, or more, options for sound level and they will all bolt to your current turbo.
RarlyL8 Muffler systems for Porsche 930
Derrick
Old 01-02-2018, 06:48 AM
I have used multiple Rarly8 muffler systems along with the factory headers and J pipes from the 70s 930 Euro systems which is similar or the same as the US 930 system from 86 onward on 77- 79 us 930s. Sounds great, heat is fine, and good increase in power and fuel mileage. The RarlyL8 mufflers can be either single or dual with different sound spec's also.
Anthony @ Voitureltd Bayside WI.
Old 01-02-2018, 07:23 AM
Originally Posted by voitureltd View Post
I have used multiple Rarly8 muffler systems along with the factory headers and J pipes from the 70s 930 Euro systems which is similar or the same as the US 930 system from 86 onward on 77- 79 us 930s. Sounds great, heat is fine, and good increase in power and fuel mileage. The RarlyL8 mufflers can be had single or dual with different sound spec's also.
I would like to retain a single exhaust.
I do like the look of this exhaust. What did it cost installed?
Old 01-02-2018, 07:26 AM
Like everything else Porsche. A BOAT load.
In case you don't know.
BOAT = Bust Out Another Thousand.
Derrick
Old 01-02-2018, 07:29 AM
Rocket Scientist
What type of attention does it require? Is it leaking, or rusted, or .... ? What year is it? The early US exhausts Ď76 to Ď79 are less common. No model year 930 used a shiny tip (not a Porsche thing I guess). Finally, state inspections may require a cat to pass the emissions test.
Old 01-02-2018, 08:30 AM
Its the original euro exhaust for 1979. Iíd like to keep the original exhaust if at all possible. Maybe I should wait to see if porsche reproduces the factory correct exhaust for 79 RoW.
Old 01-02-2018, 08:45 AM
Rocket Scientist
They do, as does aftermarket company Dansk. Hopefully you can reuse a few things, like the rear crossover.
Old 01-02-2018, 08:55 AM
puddy's Avatar
Stock is boring, go for a Rarly L8 hooligan muffler, Or outlaw pipe, if you really want to upset the neighbors!
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 01-02-2018, 09:42 AM
Sound should be a secondary concern...your focus should be on how best to increase the performance and reliability of the car with simple bolt-on mods, at a reasonable price.
Fortunately, replacing the factory turbo/header/exhaust combo on these cars is the easiest, cheapest and least-invasive way of boosting power. The factory header/turbo, in particular are crappola.
Old 01-02-2018, 09:52 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
That has never been a concern or goal of the OP's (not meant as a slam towards him, just an FYI ).
Old 01-02-2018, 09:54 AM
Un-Fortunately, replacing the factory turbo/header/exhaust combo on these cars is the easiest way to maximize your frustration level. Broken bolts and extraction are in your future.
Fixed it for you.
Derrick
Old 01-02-2018, 10:15 AM
beancounter
jwasbury's Avatar
My opinion:
Highest quality aftermarket offering with heat are SSI exchangers. I think they stopped making them and maybe sold the product line to Dansk? Not sure I recall correctly on that point.
One could argue that SSIs were better quality than Original Equipment...certainly true vs. the USA 1979 crap that my car came from the factory with
Anyway, Brian B. (Mr. RarlyL8) sold an SSI setup for the 930. Combined with one of his mufflers this was my choice.
There is a video with sound clips from my car on youtube...search "jwasbury" and you'll find it easily.
Not sure if Brian can still pull such a system together for you, but he's the "man" for 930 exhaust upgrades
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-02-2018, 11:30 AM
Originally Posted by 1979-930 View Post
Fixed it for you.
So true!
Old 01-02-2018, 11:56 AM
This is true.I am currently running B&B headers with heat exchangers and will be placing a order in the next couple weeks for Bryans headers.I am getting excited just thinking about it.Have any one of u swapped your B&B for Bryans headers?
Sent from my SM-N910T using Tapatalk
Old 01-02-2018, 12:17 PM
Originally Posted by kevin930t View Post
. . .I am getting excited just thinking about it.Have any one of u swapped . . .
Only in the land of Fruitz & Nutz!
Old 01-02-2018, 02:14 PM
U know it.
Old 01-02-2018, 02:20 PM
I can only speak to Rarelyl8 mufflers as I donít have any of Brianís headers. Fitment is terrific and customer service is awesome. I have a hooligan on my 930. Compared to the M&K on my SC itís not too loud and I love it. My family knows when Iím about two blocks away.
Old 01-02-2018, 02:42 PM
