Smart quod bastardus
turbokraft full bay intercooler pictures-installation
I am looking into a full bay intercooler for my '79 930 and wanted to see some installation pictures of the Turbokraft full bay unit.
In particular I am looking for photos other than what's on their website. I am mostly interested in seeing how the rear connection is made to the intercooler and the throttle body on the pancake manifold. Photos of the actual piping assembly and how it’s connected, mounting points, location of the blow off valve, ie. I have concerns with packaging it in my engine compartment and without photos of this piece it’s impossible to make any judgement if it works for me. I called Chris and he can’t supply me any pictures so that’s why I am asking here. Any help is appreciated. PM me if it’s easier to talk off line. I can give you my email address. Thanks Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Mine is on a 3.2 manifold, but I can show you pics of that if you want.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
Glad you found your way into the correct forum
I have a 1994 3.6 single turbo with a pancake manifold and a large intercooler but it is not a turbokraft IC and certainly not as pretty as one of Chris' pieces. Use a rubber boot between the intake and IC. ![]()
A bunch of old race cars |
Another photo
Hi Van,
Nice Garrettson IC! That uses an 8" length (fore-aft) core, so it can exit nearly vertically into a 930 manifold. TurboKraft intercoolers are usually 12" so we use a 3" diameter tube out of the intercooler into the throttle body. It's a "U" shaped tube on the 3.2 manifold setups, and a "S" for the flat manifold. Using an outlet tube lets us mount all accessories in it -- air temp sensor, idle motor port, blow off valve, etc. Sorting through 1,000+ photos from a recent project, sure to have a good on in the back of the IC outlet pipe. Will post it here. Fred -- we can put the BOV most anywhere along that outlet tube, or, leave it off for you to add on (TIG weld the flange locally).
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Here's a pic of my motor, which has all of Chris's stuff including the full bay intercooler, not pictured.
E-85 sippin drunk
Fred, Here are a few pictures of mine and what I came up with... and I agree the TK full bay I/C is pure jewelry!!!! Hope these pics better help you visualize things. Brad
[IMG] IMG_0142 by Brad, on Flickr[/IMG][IMG] IMG_0140 by Brad, on Flickr[/IMG][IMG] IMG_0181 by Brad, on Flickr[/IMG][IMG] IMG_0169 by Brad, on Flickr[/IMG][IMG] 20140426_185415 by Brad, on Flickr[/IMG][IMG] 20170627_115050 by Brad, on Flickr[/IMG]
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Chris I did not know it was a Garretson IC. I know this motor well, as it came out of a friends car, but I took it in on trade and am most likely going to sell it
Thanks for the info
This is a Tial, Intercooler, headers and turbos from the GT2 I built
TK full-width EFI intercooler's cold-side charge pipe, intercooler to throttle body, 930 with flat manifold.
The standard BOV we use is a black Raceport from Turbosmart, while the one shown is a HKS SSQV (customer request). BOV + installation (welding) is $300.
Kartoffelkopf
Some more pics for you, but using a 3.2 manifold and Fly-by-Wire 997.1 throttle body...(just mock-up pics whilst the build is in progress)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject Last edited by Spenny_b; 01-04-2018 at 11:07 AM.. |
Thank guys pictures helped a lot.
I do appreciate the responses. Fred
That's some *serious* engine porn right there, Spencer!
Kartoffelkopf
Aww shucks, I couldn't possibly comment!! Just hope it delivers the numbers, as/when.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
Spenny,maybe you can give us some specs?I have convinced my brother to finish his 930 and take his motor to T/K.
Sent from my SM-N910T using Tapatalk |
Kartoffelkopf
3.3 basis engine now running 98mm LN Nickies for 3.4 CP Carrillo TurboKraft pistons CP Carrillo steel rods Flowed heads with Schrick valve hardware Heads are twin-plugged 964 Carrera cams Carrera 3.2 Intake manifold Ford EcoBoost CoP ignition system Garrett GT35R turbo (twinscroll) 2x Tial wastegates with phase and anti-phase boost control 1x Tial BOV Syvecs (Life Racing) S6+ engine management Dual knock sensors Dual EGT sensors 964RS Flywheel 997 GT2RS Sachs clutch Fly-by-wire throttle Traction control with 4x wheel sensing and lateral G sensor ...and of course, one of Chris's TK intercoolers, front-and-centre. Full write-up with all the gory details and specs are in my thread over in the Engine Rebuilding forum, linked below ![]() And for sure, give TurboKraft a call re your Brothers car. I'd have been absolutely nowhere with my project if it wasn't for Chris.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject Last edited by Spenny_b; 01-05-2018 at 01:37 AM.. |
...and, A/C. Spenny, you win!
Kartoffelkopf
Lol!
![]() Nah, it ain't about winning anything, I got all my ideas and wish-list bits only from reading threads on Pelican. But having said that, a fair bit of effort went into shipping A/C pipework around the country to make up the custom hoses, welding bosses into place, etc. The UK doesn't seem to have as many A/C specialist or parts suppliers as you guys do (duh...our climate may be the reason). It all looks remarkably unremarkable now when I look back, but glad I did it (having spent £1200 on a new CCU only a month or 2 before embarking on this project...I damn well want to use the thing!!)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject Last edited by Spenny_b; 01-05-2018 at 04:11 PM.. |
