1967 frankenporsch
Exhaust manifold cherry Red at idle
A friend of mine 930 exhaust manifold glows Cherry Red at idle after just 5 minutes of operation. Aftermarket b&b stainless exhaust. Also muffler shows a really high temperature but not cherry red.
Timing verified, different cams checked, different mufflers, different static timing, new injectors. No misfire at all at any moment.
Different gasoline brands.
3.3 liter engine.
W3dpo Bosch spark plugs
CIS injection.
Is that normal??
Maybe he is looking for a problem where it is not.
Advice, comments more than welcome
Thanks.
1967 normale
Old 01-12-2018, 04:12 PM
16Volt's Avatar
Extremely lean mixture can cause this or way out of time.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 01-12-2018, 04:22 PM
Mr9146's Avatar
Plugged cat?
Old 01-12-2018, 04:25 PM
1967 frankenporsch
Both were supposedly inspected
1967 normale
Old 01-12-2018, 04:26 PM
1967 frankenporsch
Not cat,
Aftermarket exhaust
Thanks.
1967 normale
Old 01-12-2018, 04:28 PM
Dr J's Avatar
Timing too retarded?
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI. (Whipple Supercharger currently off for rebuild)
Old 01-12-2018, 04:41 PM
Norm K's Avatar
If your friend values his engine ... inspect again.
_
`66 912: Sold, `80 930: now resides in Poland, `84 Targa, now resides in The Netherlands, `75 911S: now resides in Northeast Germany, '83 Targa
Old 01-12-2018, 05:08 PM
1967 frankenporsch
Ok,
Im going to confirm that tomorrow
Thanks.
1967 normale
Old 01-12-2018, 05:11 PM
Crotchety Old Bastard
RarlyL8's Avatar
Check the temperature of each cylinder header primary tube. One lean cylinder can cause these symptoms while the average AFR reading remains in spec. If once cylinder is an outlier verify fuel flow at the injector for all 6 cylinders. This is assuming that ignition and cam timing has been verified and there is no occlusion in the exhaust system.
Old 01-12-2018, 06:14 PM
Turbofrog
smurfbus's Avatar
How did he check the timing? I would guess its still too retarded and remember that stock timing is way too retarded for good engine operation but was chosen for emissions. I can run my engine close to stoich and it does not get cherry red ( good amount of timing advance) and leaner than stoich starts to get cooler beleive it or not. Stoich burns about the hottest and makes least emissions.
79 930: HX40S#16, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, True split BB, 2*turbosmart38
Old 01-13-2018, 08:01 AM
29 beforehand in 4000 tr / mn, temperature of oil in 90 , for one 930 European. Too much beforehand made also too much warm the exhaust. ;-)
Old 01-13-2018, 09:19 AM
gbgastowers's Avatar
No spark can cause this. Fuel ignited when it hits cat or exhaust
Old 01-13-2018, 09:58 AM
Turbofrog
smurfbus's Avatar
No misfire though
Old 01-13-2018, 10:30 AM
1967 frankenporsch
Shop was closed today.
He has to wait till Monday.
Thanks for all the tips.
1967 normale
Old 01-13-2018, 12:44 PM
1967 frankenporsch
1967 normale
Old 01-16-2018, 01:16 PM
Turbo Powered Snow Blower
^^^ WOW! That is an issue.
I bet the heater works awesome.
Derrick
Old 01-16-2018, 01:32 PM
I would rather be driving
jpnovak's Avatar
banana in the tailpipe?
seriously, something definitely wrong. Is there some obstruction on there?
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 01-16-2018, 01:56 PM
T77911S's Avatar
he may be using the wrong timing mark....too retarded.
if he is using the TDC mark for the advance mark that will retard the timing.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 01-17-2018, 02:46 AM
