3.4L Turbo system complete for sale
I am selling my used 930 3.4L EFI system complete. This system is capable of producing 650+ HP depending upon fuel type and manifold pressure used. Single Turbo set up with less than 2000 miles from new. PM for photos and further information. This will be an opportunity to achieve this level of performance at a lot lower cost. Will entertain any reasonable offer.
The system is complete, in great condition with some parts rebuilt, and will require fitting only to use.
The system includes the following parts.
98.0mm Piston and cylinder kit. 3.4L with stock crank. Cleaned, crack checked and measured.
Twin plug head set, fresh rebuilt, new guides and new seats, ready to use. Ported with flow numbers.
Camshaft set, polished and coated
Rocker arms, rebuilt, coated.
3.2L intake manifold complete with Injectors and fuel rails, all plumbing
Large Intercooler and mounts
Exhaust complete with dual wastegates and muffler
KKK Turbocharger with drain tank
Primary single headed distributor with internal sync sensor, top plugs
Secondary single headed distributor cam driven off left side camshaft, lower plugs
All ignition wires included.
Exhaust cam covers
Mapped EFI technology EFI system with all sensors., complete engine and chassis harnesses.
M&W CDI system
Old 01-28-2018, 03:50 PM
I have four children; will part out. PM me.
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 01-28-2018, 03:55 PM
Chain fence eating turbo
The most confusing post I've ever seen here.
No brands, no photos, nothing.
Old 01-28-2018, 05:37 PM
dos531's Avatar
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
Ducati 748R
Old 01-28-2018, 07:50 PM
I did suggest to PM me for photos and further info.
But,
P&C's are Mahle
Heads are Porsche twin plug rebuilt by Performance Developments
Camshaft set is Performance Developments custom design
Rockers are Porsche, rebuilt by Performance Developments and hard chromed and ground back to original specs
Intake is Porsche 3.2L Carrera modified to fit 930 application
Intercooler is full width custom built by Jerry Woods
Exhaust is combination of SSI and custom with twin wastegates built by Jerry Woods
This engine was originally built by Jerry Woods , sold to my customer who swapped it out for an engine I had along with added $$$. It is currently at PD undergoing a full restoration back to stock and will be sold as soon as its completed. These parts are the take off parts from the original 3.4L turbo engine by JW. If you need more info, photos etc, PM me.
If you have original 930 Intake and Exhaust parts to exchange, I am interested and can work out some sort of deal.
Simon B.
Old 01-28-2018, 08:45 PM
Simon, do you mind posting the head CFM #'s?
I don't need the heads, it was just for the sake of data. Curious what the flow rate after porting.
I'm thinking about porting my Carrera 3.2 heads, and wanted to see some numbers to compare to.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-29-2018, 06:19 AM
puddy's Avatar
I didn't think a KKK turbo would work for that kind of power.
I'm curious what a package like this is worth, $10k ish?
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 01-29-2018, 10:26 AM
xbmwguy's Avatar
Thought the same. Didnít know of a KKK capable of north of mid 5s max
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2,E-85 706 rwhp
Old 01-29-2018, 04:03 PM
Originally Posted by xbmwguy View Post
thought the same. Didnít know of a kkk capable of north of mid 5s max
k29??
Old 01-29-2018, 05:26 PM
kevinbodman930's Avatar
Simon,are you selling the efi off the motor or the entire motor or bothe?
Old 01-29-2018, 06:36 PM
I'm having an engine rebuilt I swapped out a few years ago. It came as a Jerry Woods built 3.4L EFI 930 engine with less than 1500 miles. It has the Carrera manifold etc. somewhat typical EFI engine. I installed it and ran the engine for less than 500 miles. The last time the car (1989 930) was registered was 1999. I have stored it since.
I'm building it back to stock to sell, therefore all of the parts that were changed to make it an EFI engine are take off's and for sale.
I have had the shop rebuilding this engine for me, go through a lot of the parts to make sure they are perfect and have just asked them to go through everything, clean everything ready to assemble onto an engine.
The parts come complete and I will not separate. The kit is worth something as a whole and not broken up.
I will have the shop post some photos of the whole system ASAP.
Simon
Old 01-29-2018, 07:32 PM
I would like to know what it is before I commit.Can u pm the shops phone #.Thankyou
Old 01-29-2018, 08:05 PM
What are the cam specs? It would go in a healthy 3.3 w a K27 and full width intercooler.
Old 02-08-2018, 01:46 PM
I have asked for the cams to be measured. Not sure what your other request is?
Can you repeat?
Old 02-09-2018, 01:58 PM
3,4
Dear Sir,
we may have a customer for your package - please get in touch with us.
Thank you !
Dirk
Old 02-12-2018, 11:37 PM
Originally Posted by Edelweiss View Post
Dear Sir,
Thank you !
Dirk
Kinky
Old 02-13-2018, 09:49 AM
