930 Intake on a Turbo SC?
I have a '79 SC (3.0) that I am going to turbo & change to EFI. It's hard finding a complete 3.2 Carrera intake for the swap. Has anyone put a 930 intake on a turbo'd SC? Compatibility issues? Thoughts or opinions?
Old 02-04-2018, 08:42 PM
I would rather be driving
jpnovak's Avatar
3.2 intake flow so much better and be nearly port matched to your 79SC heads.
It will also be cheaper option by the time you buy 930 pancake manifold, EFI injector blocks, fuel rails, new intake studs, etc.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 02-04-2018, 08:45 PM
You could also get the Tbitz kit and modify the stock intake to run boost. I did that, it works quite well. You'll just need to upgrade to MS2 if you'd also like to go distributorless.
Old 02-05-2018, 07:47 AM
Chain fence eating turbo
I know where one is sitting....
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-05-2018, 07:59 AM
Brando
quattrorunner's Avatar
Yes it will fit.
Turbo powa!
1977 911s. it's cool
Old 02-05-2018, 09:32 AM
flat6pilot's Avatar
+1 on the T-bitz option. It will include the rails and everything you need (minus the injectors). If you can find a stripped 3.2 manifold with the throttle body, get it. it's all you'll need.
3.2 Carrera manifold on an SC
-Kyle
* 1980 911SC - 3.0l R.o.W 8.6:1 w/ Garrett 30R turbo conversion (.5 bar), Bitz MS-II EFI, Carerra intake, Zork tube, 2300lbs, 360whp
Old 02-05-2018, 09:44 AM
- Off topic, but just wanted to thank you for answering some of my questions during my conversion. I would definitely suggest going distributorless as your next upgrade.
Old 02-05-2018, 10:08 AM
Brando
Agree completely!
And also do read his thread it's a great read.....
Turbo powa!
Old 02-05-2018, 10:35 AM
Thanks for the responses guys! I’ll be on the lookout for a 3.2 intake so if you know of one in need of a home hit me up. Hill3312, thanks for posting your turbo build. It’s been informative and fun to watch. Looking forward to seeing the dyno numbers!
Old 02-06-2018, 04:15 PM
Originally Posted by utbeamer View Post
Thanks for the responses guys! Iíll be on the lookout for a 3.2 intake so if you know of one in need of a home hit me up. Hill3312, thanks for posting your turbo build. Itís been informative and fun to watch. Looking forward to seeing the dyno numbers!
Check your email, please.
Old 02-06-2018, 06:07 PM
Utbeamer, please email your address, please sir!!
Old 02-07-2018, 08:35 PM
Your intake is on its way
Old 02-08-2018, 09:43 AM
TurboKraft's Avatar
If you do not plan on porting your heads and wish to use tapered intake adapters for fitting the 3.2L on SC or Turbo heads:
https://parts.turbokraft.com/products/carrera-intake-manifold-adapter-set
Very easy to port match these adapters to your SC heads with a Dremel and sanding drum.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 02-08-2018, 11:32 AM
