Porsche Crest Mill the heads ?
Enjoying the 1981 930.Did the engine rebuild last winter. Shipped the heads out for rebuild .They said they didn't need resurfaced , but noticing some leakage between head and cylinders . Was wanting to cut .004 in. off the face and call it a day . Was wondering if I could run into any issues .
Old 02-05-2018, 05:49 PM
Have you rechecked the torque on the heads. This will also show if a stud has pulled out or broken.
Rahl
Edit; Did you replace the original head studs? If so with what?
Old 02-05-2018, 07:18 PM
All studs are tight .Replaced with Supertech .On the rebuild there were three different types of head studs so who knows how long it ran with broken studs .There are portions of the head face to cylinder that are polished , looks like head movement?
Old 02-05-2018, 09:58 PM
full quack's Avatar
Send a message via Yahoo to full quack
Higher than stock boost threshold can cause cylinder to head movement....are you running at .8 bar max stock boost, or are you pushing it harder?
Did you "fire ring" the heads during rebuild? Then use the appropriate copper rings & gaskets?
Mark
Old 02-06-2018, 11:16 AM
TurboKraft's Avatar
Milling 0.004" off the heads is no problem at all.
If you're reusing the cylinders, consider having them ground on the sealing surface to ensure they're truly flat, and that surface is 90deg to the bore.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 02-06-2018, 11:31 AM
Mr9146's Avatar
This. Surface the heads AND the cylinders. Only doing the heads is only doing half the job.
Old 02-06-2018, 12:27 PM
Mark the engine is stock no fire rings. Thanks for the .004 reassurance. Just want to remove the surface fatigued metal. And yes good heads up, will take care of the cylinders.
Old 02-06-2018, 08:02 PM
Ken911's Avatar
Some people also go to the trouble of lapping the head with the matching cylinder.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 02-07-2018, 06:57 AM
