Brando
quattrorunner's Avatar
injector trouble
Got the car to start and that's a big relief as it's a new engine to me, a new fresh build, and brand new me installed efi....
Anyway I'm only running on 3 cyls. I had to get to work but quickly but was able to throw the connectors on a voltage tester to see if maybe I wired something badly and on the two I tested I saw voltage.. Do injectors go dead? They were purchased on ebay used sooooooo. I'm looking at ID 1050x injectors new but wanted to know from the brain trust if there was something I could test or try other than swapping out injectors or whatever..
Turbo powa!
1977 911s. it's cool
Old 02-06-2018, 12:47 PM
Turbo Powered Snow Blower
You confirmed power, but what about the ground trigger? I would check continuity back to the PCM before throwing new injectors at it.
Also are you Coil on Plug? I chased two dead cylinders in COP car and it ended up being broken wires in the COP connectors.
Derrick
Old 02-06-2018, 02:18 PM
Chain fence eating turbo
What? Didn't know you went EFI?!!
What system?
Old 02-06-2018, 02:21 PM
Brando
Electromotive. Gt200. Got a larger turbo and new engine too.
Turbo powa!
Old 02-06-2018, 02:34 PM
Why were you trying to sell your 930 oil tank? Going gravity fed?
Rahl
Old 02-06-2018, 04:51 PM
Brando
Yes I got a little electric scavenge pump that works great.
Turbo powa!
Old 02-06-2018, 05:28 PM
T77911S's Avatar
its probably wiring. do you have them firing in 2 groups of 3?
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 02-06-2018, 07:57 PM
Brando
So tonight I made a new file and started it using the sequential option instead of staged. Smoother though I suspect I still have one dead cylinder. Now I’m having trouble with WinTEC software allowing me to tune it. I must be missing or doing something wrong as it is usually is me.
Turbo powa!
Old 02-06-2018, 08:43 PM
