kevinbodman930's Avatar
Hey Phillip what made you go with Ms3 pro and not Aem.
Old 02-12-2018, 12:00 PM
Chain fence eating turbo
MS was getting tired as being touted as a subpar brand, so they developed MS3Pro. They incorporated a robust case and connectors, and created a ton of I/O's for the most complicated of installs.
Another claim to fame, is whatever it offers to do (features), you get it right away and can use immediately. No paying extra like some other brands like Haltech and MoTeC.
All this while trying to be competitively priced, of course. Staying true to MS roots.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-12-2018, 12:14 PM
MS3Pro
support was also a big factor...
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 02-12-2018, 04:20 PM
Lot's of support for MS here on Pelican. There is also a very active forum on Taptalk for MS products.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 02-12-2018, 04:38 PM
Denso COP fitment
I measured the contact point of the coil with the spark plug end, and the spring in the coil barely touches the plug. Has any one else measured this... I drilled/notched the casing of the COP for deeper access. I think this is easier than to cut the rib on the valve cover. What are you guys doing, or does the spark jump from the coil to the plug? Philip
Old 02-16-2018, 12:23 PM
I cut the rib on the valve cover. I only needed to do this on #5. But I also removed the mounting boss on all the coils. This kept them clear....especially the oil line at #1.
Keep in mind that I'm still working on it. Not yet running.
-Todd
1987 911 Turbo, Marine Blue, GT35R, BB Headers, Tial, Andial IC
Old 02-16-2018, 12:51 PM
yes, that's also #5 I show in my pics. I think I'll cut the mounting tabs also... looks much cleaner. ;-)
Old 02-16-2018, 03:34 PM
I cut the mounting boss on Coil number 1 top side. I am twin plug. I also used the RSR clips to hold the coils in place.
Old 02-16-2018, 04:07 PM
xbmwguy's Avatar
The green oil return tube o rings fit nice for a tight seal without making the coil sit proud of the valve cover
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2,E-85 706 rwhp
Old 02-16-2018, 06:52 PM
Good to know!
Old 02-16-2018, 08:14 PM
engine compartment layout
So I decided to mount my devices on the vertical wall of the control panel in the engine compartment... built the injector and coil harnesses today. Waiting for 80lb Seimans Deka injectors to arrive. Anyone have injector off time curve for these injectors? https://www.ebay.com/itm/6-New-Siemens-Deka-Fuel-Injectors-80lb-840cc-80-Buick-Regal-GN-Ford-BMW-Falcon/281348994826?epid=1037410250&hash=item4181b4f70a:g:gj4AAOxy4eJTOPYv&vxp=mtr
Old 02-18-2018, 01:33 PM
for some reason, pic didn't load above...
Old 02-18-2018, 01:35 PM
Looking good Phillip. Brings back lot's of memories for me of last year,
Old 02-18-2018, 02:35 PM
I have to give a shout out to the guys for help behind the scene...
John Pilcher, big help with advise on wiring... also his awesome CAD drawings in his install thread. MS3 Pro Conversion
dos512, Derek for supplying me with the MS3Pro Evo, at a good price, and also wiring info...
Matt from DYI autotune tech support, for the quick response to any questions/tech data on the LC1 and meth injection wiring.
any info I need is only a message away. ;- you guys all make this a enjoyable experience... Philip
Old 02-20-2018, 03:41 PM
Glad to hear you are enjoying the install Phillip.
Old 02-20-2018, 04:07 PM
dos531's Avatar
Glad I could help!
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
Ducati 748R
Old 02-20-2018, 04:25 PM
'76 911S 3.0's Avatar
Here you go
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 02-20-2018, 05:05 PM
Originally Posted by '76 911S 3.0 View Post
Here you go
thanks Jayson...
Old 02-20-2018, 05:18 PM
dos531's Avatar
Also, check your voltage in the ms3pro against the actual voltage at the injector. On mine it was about 1 volt off before I calibrated, which threw things off before I realized it wasnt accurate.
'01 996tt
Ducati 748R
Old 02-20-2018, 06:15 PM
TurboKraft's Avatar
COP ignition looks good with RSR hold-down tabs:
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 02-20-2018, 06:27 PM
