I would rather be driving
jpnovak's Avatar
This is my number one complaint with all the high-end ECUs. The top mount wiring prevents installations in areas that are discrete. Top wire routing works well for electronics boards where everything is open for access but not so much for underseat, heel panel, or other mountings.
I prefer all connections on one side of the box and not on the top.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 02-26-2018, 08:15 AM
Thanks Guys!
That was my concern. Mounting under the seat to keep it clean, but with the top mount wiring and having to bend the crap out of the harnesses to get it to clear a factory seat, clearance looks like a possible issue.
Jamie, completely agree. it's a lot easier to surface mount everything in production and let the end user figure it out!........not!
They could, at a minimum, provide a harness option with nice low profile 90 degree plugs. But that would cost too much, or take too much effort!
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 02-26-2018, 12:50 PM
I didn't think it would turn out this well either... but as you can see, the wires are turned almost 90* to the connector at the ECU.
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 02-26-2018, 03:29 PM
good tutorial on EFI grounds
good info...
https://www.youtube.com/watch?v=EJ2TeodWDUE&feature=youtu.be
Old 02-28-2018, 04:14 AM
Chain fence eating turbo
I know an online guy who is making a cover, if you will, that goes over the top of the connectors and routes out from the sides of the Pro box for more discreet installations.
He only has the design for the Gen 1 Pro's though.
If there's any real interest, I'll pass it along to him.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-28-2018, 04:17 AM
Andy has some great videos. Make sure you subscribe. His videos have helped me out a lot.
Phillip you should be able to fab up a sheet metal cover. How is you progress coming?
When do you think you will be ready to fire?
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 02-28-2018, 08:28 AM
Hey John, no progress this week, I've been down with the flu... I'm leaving for the DR this weekend for 6 weeks, hope to get some maps loaded, and figure out the laptop end, which is a bit more challenging for me... may need lots of help here. Philip
Old 02-28-2018, 02:50 PM
GSF pully install
Well, I'm back at it... hope to get this done in the next couple of weeks. Today I test fit my GSF crank pully/toothed wheel. I had to take the die grinder to the fan housing so it will fit. Not a biggie, took about 20 minutes...
Old 04-17-2018, 05:04 PM
hall sensor
installed the hall sensor in the scavenge pump today for sequential injection. Gapped it at 1.5 mm. I havn't looked up the VR sensor gap, anyone have it on hand? Philip
Old 04-22-2018, 03:25 PM
carrera head temp sensor
I'm using a Carrera temp sensor in the heads... sure is a tight fit to get it to go behind the scavange pump. Still have to put the tin on, just a test run, Anyone have any experience with this, or installed one in a NA Carrera.
Old 04-22-2018, 04:11 PM
Making some good progress Phillip. I set my gap to 1mm on the cam sensor.
Old 04-22-2018, 04:47 PM
Hey John, what gap did you set your crank sensor at? Philip
Old 04-22-2018, 04:59 PM
I have both set to 1 mm.
Old 04-23-2018, 08:33 AM
dos531's Avatar
I believe my sensor gap is somewhere around there as well. The spec is going to depend on which sensor you're using. That said, I didnt even measure the gap on my cam sensor since I didnt disassemble the scavenge pump so it wasnt accessible. I just tightened it down til it made contact with the magnet, then backed it off a couple turns. Havent had any issues.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
'86 190E 2.3-16
Ducati 748R
Old 04-23-2018, 09:01 AM
Well, there was no way the wire for the Carrera cylinder head temp sensor was fitting under the tin. It left too much of a buldge, and the scavenge pump wouldn't pull tight to the cam tower. I ended up drilling a hole in the tin and this should work fine...
Old 04-24-2018, 04:08 PM
I have all my wires identified so I can easily connect then to where they belong Almost everything figured out now...I'll put the engine in place so I can figure the wire lengths.
Old 04-26-2018, 12:13 PM
'76 911S 3.0's Avatar
Now the real fun begins
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 04-27-2018, 09:43 AM
lite75's Avatar
pull some extra wires too, always something you want to add later..
75 930, 76 930, 83 SC EFI turbo
Old 04-27-2018, 09:56 AM
Ken911's Avatar
Can the MS3 pro be installed in the engine compartment instead of in the cab since it doesnt fit under the seat?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 04-27-2018, 09:58 AM
dos531's Avatar
The ms3pro fits under the seat, that's where mine is mounted. You're thinking of the MS3X. It is not recommended to mount it in the engine compartment.
'01 996tt
'86 190E 2.3-16
Ducati 748R
Old 04-27-2018, 10:12 AM
