Ken911's Avatar
i know the ms3x cant be thats the one i currently have. But i was planning on getting a ms-3 pro but but have been thinking of mounting it in the engine compartment and putting a subwoofer under the seat.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 04-27-2018, 10:21 AM
MS3 Pro
Hi Ken, I don't think the MS3Pro is available anymore... Mine is the MS3Pro Evo, I have it mounted on the rear kick plate behind the drivers seat. Fits well in that location, and the carpet covers it nicely. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 04-27-2018, 02:04 PM
Originally Posted by lite75 View Post
pull some extra wires too, always something you want to add later..
I ran 2 extra wires into the cab...and pulled 3 back to the cab from the harness for meth injection, tach, and LC 1. Hopefully that will do.
Old 04-27-2018, 02:08 PM
Ken911's Avatar
That's what I meant whatever the latest version of the pro is.
Old 04-27-2018, 02:34 PM
all wired
finished the wiring, going to put the engine back in today...
Old 05-02-2018, 04:53 AM
Looking Good Phillip.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 05-02-2018, 08:45 AM
Work in Progress
Rich76_911s's Avatar
Damn, that's impressive. I'm going to save that photo and have it as a reminder of what's really involved with an EFI swap. Because what you've done there looks way above my pay grade!
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 05-02-2018, 09:03 AM
ECU location
The ECU fits nicely on the kick plate behind the seat, and the carpet covers it well. Now if I could only find the bolts for the seats...
Old 05-02-2018, 10:57 AM
Looking good Philip!
As a side note, I caved in. Put the MS3 kit back in the box and order a MS3Pro Evo.
Came in a couple of days ago.......
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 05-02-2018, 11:48 AM
Great... you going COP ? It makes things really simple.
Old 05-02-2018, 11:51 AM
Going with Denso motorcycle COP's powered by a M&W CDI.
935 Suspension with Moton Coilovers for the street
1986 911 Turbo
Old 05-02-2018, 12:05 PM
I'm not familiar with that setup, but why not let your MS ECU look after everything?
Old 05-02-2018, 03:02 PM
The MS ECU will fully control the spark, except dwell. The M&W is basically a 'dumb' box that has 6 low voltage inputs and 6 high voltage outputs. The MS will provide the 5V low voltage square wave trigger signal to the M&W. The M&W will send a 460V capacitive discharge pulse to the coil. One of the hottest sparks out there.
https://www.mwignitions.com/pdf/Pro-16b%20S3%20instructions.pdf
Those coils are 2-wire without any kind of an ignitor, so the M&W box is more of an ignitor with very high voltage.
1986 911 Turbo
Old 05-02-2018, 03:19 PM
gumba's Avatar
I spead the ramps and cut the inner lip about 36 long to be able to drop the motor inside the rear posts.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 05-02-2018, 03:33 PM
Hey Phillip
Any progress?
Old 06-18-2018, 03:25 PM
Chain fence eating turbo
MS handles dwell
Old 06-18-2018, 03:32 PM
Originally Posted by Tippy View Post
MS handles dwell
True, but the M&W CDI box only needs a trigger and can accept a dwell range of 0.5-1.0ms. All the magic happens in the box. Once triggered, the box sends a high 480V capacitive pulse to the coil.
1986 911 Turbo
Old 06-18-2018, 03:51 PM
Originally Posted by jpilcher View Post
Hey Phillip
Any progress?
+1
Inquiring minds
1986 911 Turbo
Old 06-18-2018, 03:52 PM
+1
Inquiring minds
I have the car running and tuning is in progress... My LC1 crapped out, so waiting for the new one to arrive... I had no problem with the wiring/install, but I'm a little challenged with the programming portion of the tuning ;-). Hopefully next week I'll be driving.
Old 06-18-2018, 06:12 PM
Sooo, I have my new AFR gauge (LC2) installed... still running very rich. I tested the running fuel pressure, and this is one place i have a problem. My 5 yr old 964 FPR is running 59 PSI, were I have 43 PSI set in my FUEL PUMP AND PRESSURE CONTROL settings. (easy fix) but I should look at a new FPR... whats suggested as a good model ? Do I need a rising rate FPR ?
Now I have a couple of questions as to the operation of the fuel pumps... when running the pumps in test mode, I have what sound like a bit of cavitation, sounds like air bubbles... on the pressure gauge I installed, I see a fluctuation when this noise occurs, the pressure drops about 10 psi and the needle bounces quickly for about 3 seconds. this happens once every 30 seconds...
This is with a new rear Bosch 044 pump, and stock front pump. I know this setup is overkill for EFI, has any one else had a similar problem with their pump system, and were shall I go from here, or just live with it... what are my options/opinions please. Philip
Old 06-24-2018, 01:47 PM
