Originally Posted by philip j View Post
Hey John, yes already split the fuel pumps/upgraded the fuses... depending what I find in the next couple of days, I might just upgrade the wiring, and run the front pump only, and have the ECU trigger a new relay for it... should still be plenty of fuel, and line size for 600 HP, and I don't think I'll be over that with the gt3582r. Any suggestion on what size wiring I could get away with if I go this route?
Hey Phillip
Here is a simple chart.
https://www.bing.com/images/search?view=detailV2&ccid=%2fpC63orl&id=0D29784B3C062883D735463961DE804AD789C5A8&thid=OIP._pC63orlELxp_dAaOu-vMQHaEZ&mediaurl=http%3a%2f%2fwww.autorewire.com%2fimage%2 famps-wire-gauge-size-chart_436020.jpg&exph=593&expw=1000&q=automotive+Wire+Gauge+Size+Chart&simid=608025263954527316&selectedIndex=3&ajaxhist=0
I believe the pumps are drawing 15 amps.
Let me know how you make out.
Regards
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 07-04-2018, 06:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
Phillip,
If you can get away with one pump for your horsepower level, that's the best way, less failure points. The factory only used two pumps in series to get the pressure high enough for CIS.
I found the following graphs useful when I was laying out my fuel system:
As far as wiring goes, wiring is cheap and better to do just once, so FWIW I used 10 GA. The 044 can surge up to 20 amps on startup. I would break out the wiring to the relay and fuse and make sure I have 10GA all the way through for less voltage drop.
Battery -> fuse -> relay -> pump.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 07-05-2018, 07:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Originally Posted by WinRice View Post
Phillip,
Great info... thanks for sharing. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 07-05-2018, 08:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
Well, I have her running great.... thanks to the help from my friend Dave, and should be ready for the dyno next week. the tuner asked if I had a knock sensor installed. Has anyone experience with this type of sensor?
https://www.boschautoparts.com/en/auto/engine-position-sensors/knock-sensors
Old 07-06-2018, 02:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
dos531's Avatar
I use this one
https://www.amazon.com/Bosch-0261231006-Knock-Sensor/dp/B00BHHYVHS/ref=sr_1_1?s=automotive&ie=UTF8&qid=1447974816&sr=1-1&keywords=0261231006
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
Ducati 748R
Old 07-06-2018, 10:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
ordered one... should have it this week. https://www.amazon.ca/Bosch-0261231006-Knock-Sensor/dp/B00BHHYVHS/ref=sr_1_1?ie=UTF8&qid=1530998088&sr=8-1&keywords=bosch+knock+sensor+006 Going to make a appointment for the dyno, hopefully the following week... just tying up some loose ends. ;-)
Old 07-07-2018, 02:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
FWIW same ones I ordered awhile back.
I have nothing else to add, since mine doesn’t run yet, but definitely want to see how well you get knock sensing to work. I’ve read mixed reviews.
1986 911 Turbo
Old 07-08-2018, 02:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
I have nothing else to add, since mine doesnít run yet, but definitely want to see how well you get knock sensing to work. Iíve read mixed reviews.
I didn't install the knock sensor, as I did not hear good things about them either... but the tuner says he has no problems setting them up to work, he says they are a good tuning tool for the dyno. I think it takes part of the guess work out of the equation on his end.
Old 07-08-2018, 03:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
bath before the dyno... tomorrows the day. anything I should be taking? I have oil, plugs, tools, extra can of gas.
Old 07-18-2018, 09:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
lite75's Avatar
Nice job on getting it ready to go, bet the results will be impressive! Almost the same as my build and it's running great.
75 930, 76 930, 83 SC EFI turbo
Old 07-18-2018, 10:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Originally Posted by lite75 View Post
Nice job on getting it ready to go, bet the results will be impressive! Almost the same as my build and its runs great.
any idea/estimate what numbers your build is putting out?
Old 07-18-2018, 12:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
lite75's Avatar
Haven't had it on the dyno yet so its hard to say. However, comparing it to the last CIS 930 I had on a chassis dyno that was putting down 375 this feels much stronger in every aspect.
Old 07-18-2018, 01:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
Any update on dyno Phillip?
Old 07-19-2018, 06:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Hey John, we were making some good numbers, but ran out of time... have to re schedule for next Thursday to complete...
Old 07-19-2018, 08:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
Chain fence eating turbo
I just read your sig and see we have near identical engines.
I have a larger turbo, but you have Xtreme manicured heads and meth.
Anticipating your numbers! GL!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 07-20-2018, 05:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
We had a few glitches tonight, but ended up with a conservative tune... I don't think the HP/torque numbers are any higher with the MS, than they were with SDS ECU I removed, but the fuel mileage is definitely better and the all round starting/idle is better
Old 07-26-2018, 08:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Old 07-26-2018, 08:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
Old 07-26-2018, 08:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
puddy's Avatar
Wow nice numbers Philip!! If you're ever passing thru Oshawa please take me for a ride!
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 07-27-2018, 03:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Hey Phillip
Did you have the meth injection activating?
Good numbers. Whatís your ignition table look like?
John
Old 07-27-2018, 05:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
