-   -   MS3Pro Evo install (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/987093-ms3pro-evo-install.html)
philip j 02-09-2018 02:43 PM
MS3Pro Evo install
I picked up my goodies from the shipper today. Going to swap out my SDS for the MS3 Pro. I'll post my progress, and seek some tips from those who have already done this install... going COP and sequential fuel and ignition. I'm going to pull the engine to do a general cleanup, and remove the SDS which I installed approx. 5 years ago. SDS was a good starter set, but MS has more options which I am looking forward to figure out. Philiphttp://forums.pelicanparts.com/uploa...1518226905.JPG
Tippy 02-09-2018 02:52 PM
I'm so jelly. That's the bees knees right there!
One day....
Sub'd
WinRice 02-09-2018 03:34 PM
Definitely tuned into this one!
I have the whole MS3 + MS3X kit on the bench ready to build, but may save it for another project and go MS3 Pro EVO to save time.
Looking forward to the results!
Tippy 02-09-2018 03:49 PM
Trade you an assembled DIYAutotune MS2 V3.57. ;)
jpilcher 02-09-2018 04:08 PM
Wow, Phillip that's very cool. So jealous. What are your plans? Injectors? Boost control? Wideband?
You should check out the MS Pro Gauge from Perfect Tuning. https://perfecttuning.net/en/
Looking forward to this build.
philip j 02-09-2018 04:41 PM
Hey John, nice gauge, but for now I'm just going to stick with the Innovative LC1 I already have installed. It's pretty well just a easy swap right now, with added COP, bigger injectors, sequential, just want to get it up and running, and master the tuning... but you know how it goes.... I'm sure I'll be hitting you up for some info, as your already a few steps ahead of me, and your install looks like a success. I want to get as much done in the next 3 weeks before we go back to our winter playground till spring. So, I'm going to have a busy schedule... ;)
jpilcher 02-09-2018 04:55 PM
Are you planning on going with the Toyota COPs? They work great! I am doing the Perfect Tuning Gauge in the spring. Along with a LSU 4.9 Bosch Wideband. It's suppose to be more accurate.
Just hit me up anytime for any info.
philip j 02-09-2018 05:15 PM
Yes, already sourced the Denso COP's, and picked up one of Albert's GSF crank trigger/pulley. Porsche 911 Crank trigger pulley adapter kits with A/C | eBay
might get my meth injection connected to the MS, all depends how much time the install takes...
WinRice 02-09-2018 07:44 PM
Sad thing is, Iíve got one of those in a box too. First one I built years ago as an experiment.
WinRice 02-09-2018 07:51 PM
Which injectors are you using?
Tippy 02-09-2018 07:55 PM
Been wanting to do a V3.0 myself.
philip j 02-09-2018 08:19 PM
thinking of trying some Siemans Deka #80... see quite a few threads where they have been used. The Siemans Deka #57 I have in now work well, just the duty cycle is way up there. Anyone have any Injector Dynamics they want to sell ? Don't want to spend the money on a new set of these just just yet!
jpilcher 02-10-2018 05:41 AM
How much boost are you planning on running? If you have the injector data for your 57s, it will go along way to help optimize the VE table. If you are not planning on running E85 gas you might not need the Deka 80s. I found my Bosch 57 injector duty cycle was well below the 80%. at 1 bar.
Mind you I haven't found a stretch of road to truly test the car to red line.
Tippy 02-10-2018 05:49 AM
I've been pretty happy with my Deka 80's. Idles good enough for me, even with MS2.
They were only $300 off eBay. Read some are counterfeit, guess I was lucky.
The older Deka 55 low-Z's idled poorly.
dap930 02-10-2018 07:50 AM
I am running Siemans Deka #55 injectors on my 3.0 liter. I am tuned for 1.2 bar boost. I exceed 90% DC when pulling 6500 - 6800 RPM, particularly when it is cool out and making good power. Injector PW is a little over 18ms, making it difficult to get all the fuel in and still be sequential at those engine speeds. AFR's are still 11.4 - 11.5 which is good. I had to adjust injector timing to end the injection pulse over halfway into the intake stroke at those engine speeds. I plan to upgrade my injectors to correct this. So I would start with a larger injector to give yourself some extra headroom for tuning. I started out with 44# injectors which were way too small. I should have gone at least 60# injectors.
philip j 02-10-2018 12:35 PM
Good point John, I did install the 964 FPR to bump up the pressure... I only run 1 bar, but it spikes to 1.2 on my tell tale boost gauge, even with the 1.75" exhaust and twin 38MM waste gates. I may wait to see what MS can do with theses injectors...but they are low impedance injectors. No E85 in the plans for me. Philip
jpilcher 02-10-2018 02:44 PM
You definitely want the Hi Z injectors. I would go with the Deka 80s. That will give you lot's of overhead, for the future if you decide to up the boost. Just make sure you get all the injector data.
xbmwguy 02-10-2018 03:11 PM
Iíve got a set of deka 60# Iíll sell cheap. Only used about a month until I went e85
160.00 shipped
philip j 02-10-2018 05:45 PM
4 post engine drop...
Well I saw a thread on the 4 post engine drop... thought I'd try it. ;-) Engines all un hooked, and ready to drop tomorrow.
http://forums.pelicanparts.com/uploa...1518324154.JPG
jpilcher 02-11-2018 07:40 AM
Looking good Phillip.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
