yeah the Porsche seals are not so expensive, but the scrapers are $35 each.
John
1979 930 - mahle 3.4 (7.5:1),Turbokraft longneck IC, Leask WUR w/rpm solenoid,sc cams, rarlyl8 headers, tial wg, 1 bar boost, GT35R
Old 03-05-2018, 05:13 AM
911tracker85's Avatar
understand those cheap rebuild kits probably only have dust boots, not scraper rings. not the same. learned that on my 951 when I found some size piston scraper ring NLA for it.
wish I took good pics, but I modified the dust boot to work on the caliper piston where I ruined the scraper rings prying them out. only destroyed that one, then left the scraper rings in place and only replaced the seals on all the others.
a little complicated to explain. but as commented it only keeps dirt out, and I pull/check all my brakes between every DE event. got the 951 in the shop now for the full spring track prep.
good luck.
Bob Cox
84 928S, Ruby Red linen/brown interior - preferred DD
87 924S resurrect and gut and another track car...
86 944 turbo my new DE/track car.
78 930 clone project car.
Old 03-05-2018, 07:07 AM
good luck.
The URO scraper rings look just like the Porsche ones for the 930 calipers, the place in China probably make all of them.
Old 03-05-2018, 07:41 AM
Ordered a sett so will compare when i get them. It says that it comes complete with scraper rings and seals. And lists the equivalent porsche partnummbers.
https://www.uroparts.com/uro/inventory/show/8867
John
Old 03-05-2018, 07:47 AM
Your photos #2 & #3 showing the grooves are pretty edgy to me. If/ when the calipers are completely cleaned and it is clear that the corrosion pitting has compromised some of the three surfaces (especially the bottom ) of the primary seal groove MOVE ON TO NEW OR BETTER CALIPERS! Brakes are not something to compromise over especially with these cars that can generate (and usually do) triple digit speeds.
You and all are worth the money spent for excellent brakes for C..... sake. No messing around in this area.
If you are still unsure then take the calipers to a local expert for verification.
Again, you and that lovely lady in the 1st officer's seat are worth it!
Gman
Old 03-05-2018, 07:45 PM
Gman, could not agree more that brakes should be 100%. That's why I startet this thread to get help and opinions from all the great people here
I'm getting a smal dentists mirror so I can inspect all the surfaces of the groves, and also trying to make a small adapter for my sodablaster to get a better "blast" in the grove.
So if any of the surfaces on the grove is compromised the recommendation is to move on to new calipers, or at least get them verified by a local brake shop.
John
Old 03-05-2018, 11:25 PM
what was the price from URO? cant figure out how to find that.
your link shows a set for the front, do they also have rear?
I'll have to check them to see if they also have scraper rings for the 951.
Bob Cox
Old 03-06-2018, 05:26 AM
yes, they have the same sett for rears. https://www.uroparts.com/uro/inventory/show/8868
I payed $31 each. Was on sale yeasterday, now it seems to be $47.
google PO-930RBCKIT and you should fine some prices
John
Old 03-06-2018, 05:43 AM
