freesaints's Avatar
Fresh air vent question
I was trying to do a few smaller projects (replace hood struts, hood seals, etc) including replacing what looked like old, cracked seals behind the fresh air vent. When I pulled it off, there was just a bunch of dried up pieces of rubber and grime. I ordered the seal that I thought was correct (#24 on the PET) but it doesn't look like it is. It also looks, based on other threads, that this same part was sent out to others looking for #24 (#901 571 325 32). It's round and doesn't have the squared corners. Plus it looks thicker.
My question is, what needs to go between the air vent screen and the body itself? You have the frame on the outside, then the screen, then what? Based on the PET diagram, it looks like there's supposed to be some sort of seal, but for the life of me I can't find it online. I've heard others say that they just use gaffers tape, or some type of black tape to keep the screen metal from scratching the paint. Wouldn't water leak around the edges if so?
Not sure what to do here.
Old 03-03-2018, 04:15 PM
freesaints's Avatar
Accidentally posted the wrong PET.
Old 03-03-2018, 04:18 PM
The grey seal you have is #24, but it goes on the fan box #3 and seals the box to the back side of the cowl. If you feel around edges of the three vent holes you'll get the idea.
The screen just has a little black cloth tape wrapped around it, front and back, that gets sandwiched between the cowl and grill.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 03-05-2018, 12:02 PM
freesaints's Avatar
What was interesting was that when I pulled off the grill, there was definitely a gray seal (dry rotted) there. Maybe an aftermarket thing? Not sure. Anyhow, I decided to rig up my own seal using marine weatherstripping. It's worked great. After cleaning and touching up the black on the grill, I think it looks/works great.
Old 03-07-2018, 04:52 AM
freesaints's Avatar
Old 03-07-2018, 04:54 AM
