915 and 930 tunnel shift rod the same?
Looking at 4spd in my 74 911, wondering of the shift rod in tunnel is same?
Old 03-02-2018, 05:53 PM
gearhead
I'm basing this directly off of PET and no actual experience with the conversion. What I see is that the early turbo carreras with short bell housing do use the same shift rod as 915. PN 911.424.020.00
The later long 930s use 930.424.241.00. Just a guess here but I suspect this rod is shorter to accomodate the gearbox being pushed farther forward in the car.
Assuming you shorten the 930 to make it fit, my inclination is that you will not need to change the rod. Hopefully someone who has done it will comment.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-03-2018, 07:22 AM
Brando
quattrorunner's Avatar
As Matt says....
I shortened one to fit a long 930 only to have to again lengthen it when the long 930 didn't fit 1.1"
Turbo powa!
1977 911s. it's cool
Old 03-03-2018, 11:24 AM
