Headlight relay ground question
The kit I have has two 16 gauge wires for grounds coming off the relays. However, they are too short to make it from the fuse box area to the ground point near the battery. Can I combine the two 16 gauge to a single 14 gauge for about 12 inches to reach the ground point?
Thanks.
Old 04-01-2018, 11:20 AM
Alan L's Avatar
I think there is another ground point in the opp direction from the fuse box - near the hood stay?
I am not near my car right now - so going by memory.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-01-2018, 03:26 PM
Oldspool87,
Which kit are you using?
Rahl
Old 04-01-2018, 06:47 PM
76 911S Targa
The answer is yes. You can take them both to ground through a single wire. I ran mine directly to the negative post on the battery.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-01-2018, 06:48 PM
Originally Posted by 356911930 View Post
Oldspool87,
Rahl
Rahl,
Itís a kit from Carmagic (same guy with the LEDs). Technically the kit I have is for earlier cars. The difference is the wire length.
Thanks.
Old 04-02-2018, 01:56 AM
T77911S's Avatar
Alan
yes there is.
you can combine the wires.
use the one alan mentioned, then you don't see add on wires running thru the car.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 04-02-2018, 03:27 AM
