-   -   Cylinder head temp gauge (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/992530-cylinder-head-temp-gauge.html)
gumba 04-03-2018 11:44 AM
Anyone running one or two. If so, what cylinder.
brcorp 04-03-2018 12:04 PM
Running one off cyl # 3.
gumba 04-03-2018 02:52 PM
Where did you attach the sensor?
JJ 911SC 04-03-2018 03:09 PM
The easiest way is a ring around the spark plug base: https://www.google.com/search?q=cylinder+temperature+sensor&client=safari &rls=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjCg5q InJ_aAhULoFMKHb2mDtYQ_AUICigB&biw=1440&bih=735
jwasbury 04-03-2018 03:56 PM
I ran one on cylinder 6. My reasoning: in the back of the engine furthest from the fan, and next to the oil cooler. Its also been my observation that #6 in often the one that shows detonation damage (albeit my sample size is far to small to be statistically significant). Used a ring terminal under the spark plug to connect with thermocouple wire.
gumba 04-03-2018 04:06 PM
I was going to go with one on #3 and one on #6 using a Westach dual cht gauge. Did you run the sensor wire up the spark plug wire and through the valve cover plug?
jwasbury 04-03-2018 04:10 PM
Yes. The thermocouple wire comes up out of the spark plug hole in the valve cover. Did not interfere with the spark plug wire/cap.
brcorp 04-03-2018 05:26 PM
I monitor CHT through my ECU, sensor mounted via TurboKraft
https://parts.turbokraft.com/collections/front-suspension-steering/products/cylinder-head-temperature-sensor-set
JFairman 04-03-2018 05:28 PM
I had a VDO one too. Thermocouple wire sender was on #5. Your reasons for putting it on #6 sound good.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
