gumba's Avatar
Cylinder head temp gauge
Anyone running one or two. If so, what cylinder.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 04-03-2018, 11:44 AM
Running one off cyl # 3.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces for paint
Old 04-03-2018, 12:04 PM
gumba's Avatar
Where did you attach the sensor?
Harold
'79 930/DP935
Old 04-03-2018, 02:52 PM
83 911 Production Cab #10
JJ 911SC's Avatar
The easiest way is a ring around the spark plug base: https://www.google.com/search?q=cylinder+temperature+sensor&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjCg5qInJ_aAhULoFMKHb2mDtYQ_AUICigB&biw=1440&bih=735
Who Will Live... Will See
Old 04-03-2018, 03:09 PM
beancounter
jwasbury's Avatar
I ran one on cylinder 6. My reasoning: in the back of the engine furthest from the fan, and next to the oil cooler. Its also been my observation that #6 in often the one that shows detonation damage (albeit my sample size is far to small to be statistically significant). Used a ring terminal under the spark plug to connect with thermocouple wire.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 04-03-2018, 03:56 PM
gumba's Avatar
I was going to go with one on #3 and one on #6 using a Westach dual cht gauge. Did you run the sensor wire up the spark plug wire and through the valve cover plug?
Harold
'79 930/DP935
Old 04-03-2018, 04:06 PM
beancounter
jwasbury's Avatar
Yes. The thermocouple wire comes up out of the spark plug hole in the valve cover. Did not interfere with the spark plug wire/cap.
Jacob
Old 04-03-2018, 04:10 PM
I monitor CHT through my ECU, sensor mounted via TurboKraft
https://parts.turbokraft.com/collections/front-suspension-steering/products/cylinder-head-temperature-sensor-set
Bill
Old 04-03-2018, 05:26 PM
I had a VDO one too. Thermocouple wire sender was on #5. Your reasons for putting it on #6 sound good.
Old 04-03-2018, 05:28 PM
