puddy's Avatar
Innovate motorsport AFR gauge help
I'm installing this gauge
MTX-L PLUS Digital Wideband Air/fuel Ratio Gauge
The cable that comes with the kit is 8' long, this cable goes between the O2 sensor and the gauge cables. It seems to be about 2-3 feet too short for where i'd like to route it. So far I have it routed down thru the transmission tunnel which is the shortest most direct route possible. It comes out in front of the trans axle and would have to run straight back across the centre of the engine case. But I don't want to do that, I was hoping to have it go around the motor and avoid the header area.
What have you guys done? I know some of you have this gauge. Did you find an extension cable or make your own extension cable?
I checked their website and the section for Accessories and replacement parts seems to be down.
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 04-10-2018, 03:02 AM
puddy's Avatar
Ideally I need a 3-4' extension cable with these ends on it.
Cheers, Chris
Old 04-10-2018, 03:05 AM
Old car guy.....
Hot Euro's Avatar
I have had their LM2 and a separate fuel pressure gauge for a couple of years. When I first installed the LM2 I felt the sensor cable was too short 8 ft I think and ordered their longer cable which was maybe 12 ft and cured the problem.
I would try to call them or you can try one of their authorized dealers such as:
Accessories
good luck!
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 04-10-2018, 04:49 AM
Innovate makes an 18' extension cable, they typically sell for ~$75 new. Here's one for $55 on eBay.
Old 04-10-2018, 07:00 AM
puddy's Avatar
Thanks fellas, 18' is way too long! Any reason why I couldn't splice a 3' section into my 8' cord?
Cheers, Chris
Old 04-10-2018, 07:59 AM
For $50 why bother? The OE extension gives you the ability to route ideally, any excess can be neatly tucked in dash or floorboard.
Old 04-10-2018, 09:03 AM
puddy's Avatar
I can't spare the weight of 8' extra feet of cable, are you crazy!?
OK maybe I"ll just do that.
Cheers, Chris
Old 04-10-2018, 10:06 AM
I ended up using the extension cable in my car.
Old 04-10-2018, 10:37 AM
I ran mine into the glove box... I don't remember having 8' of excess for what it's worth. Love the gauge though, it's much higher quality kit than the AEM it replaced.
puddy's Avatar
OK, i ordered the 18' cable to replace the 8' that came in the kit. At least all have all kinds of routing options now.
Cheers, Chris
Old 04-11-2018, 03:28 AM
Chain fence eating turbo
I spliced mine and lengthened by about 6' IIRC.
I asked if this is ok, and the majority said yes. A few said it would screw up the calibration.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 04-11-2018, 05:59 AM
Turbo Powered Snow Blower
Haha. That's funny.
Derrick
Old 04-11-2018, 07:10 AM
When I had one with the gauge installed in the center console I bought the Innovate extension cable.
I didn't want to shorten it so I looped the excess cable around in a circle under the passenger seat so it was hidden from view.
It worked.
Old 04-11-2018, 09:17 AM
puddy's Avatar
I'm seriously considering lengthening my existing cable, i've have the 18' extension cable on order for almost a week, bought it thru Amazon prime but since its thru one of their vendors the delivery timing is over 2 weeks! I was hoping to have everything together for the weekend!
Cheers, Chris
Old 04-18-2018, 03:58 AM
^^^ I hate that about Amazon. I ordered some Threebond 1104 sealant and it took five weeks
Derrick
Old 04-18-2018, 06:17 AM
puddy's Avatar
I FINALLY got my 18' cable friday afternoon, perfect timing. Routed it the longest possible route, thru heat channel on passenger side and only had about 3' of excess cable I had to tie up under the dash. I removed my ash tray and screwed the gauge up to the underside of the dash where the ash tray was. Fits in there nicely. Nice to finally have a proper AFR gauge in the car! Took her for a rip, and she goes better than before with new turbo, boost come on sooner and more linear delivery. But apparently i'm running way too rich, gonna look at that next...
Cheers, Chris
Old 04-23-2018, 03:45 AM
