puddy's Avatar
FYI here is my WUR setting from Brian in 2015. Nothing has changed since this other than my upgraded K27 turbo last month. However I think the previous owner tuned it to be rich back in early 2000ís when he was racing.
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 04-30-2018, 04:31 PM
puddy's Avatar
My Cold Pressure seems to be 1.4 bar at 60 degrees. Much lower then what is on Brian's WUR spec sheet. Can that change on its own?
Warm Pressure is 3.75 bar
My Enrichment Pressure seems to not change when I add .9 bar of pressure. It only drops to 3.7
Ok I think my mityvac isn't working right. The pressure didn't drop, then sometimes it would go down to 3.2 from 3.7.
I tried changing my full throttle enrichment a little and raising my warm pressure by 1/4 turn. I'll drive it tomorrow and see how the AFRs look.
Cheers, Chris
Old 04-30-2018, 05:13 PM
puddy's Avatar
To confirm, raising the warm or cold pressure will richen the mixture, lowering the pressures will lean it out?
Cheers, Chris
Old 04-30-2018, 06:03 PM
Alan L's Avatar
No , other way around. A higher WUR pressure makes it harder for the airplate to move so the fuel metering piston does not dispense as much fuel for a given airflow = leaner.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-30-2018, 09:30 PM
Alan L's Avatar
My cold pressure seems to be 1.4 bar at 60 degrees. Much lower then what is on Brian's WUR spec sheet.
Warm is 3.75 bar
my enrichment pressure seems to not change when I add .9 bar of pressure. It only drops to 3.7
I tried racing my full throttle enrichment a little and raising my warm pressure by 1/4 turn. I'll drive it tomorrow and see how the AFRs look.
You need to tweek it with the WUR gauge fitted - so you can see how much adjustment you have. To still be in spec you could go to 3.8 bar WP - which is negligible increase. But if you are seeing AFrs in 12s now at top end - that is about right. need to concentrate on the boost dump pressure and the transition point (Leask switch).
Alan
Old 04-30-2018, 09:32 PM
puddy's Avatar
I took the car for a rip this morning, and AFR were at about 15-14 at idle cold, and going down the road at speed limit i'm leaner at 15 even a quick dip into 16, but when I get into boost it goes up to 9-10 then back down to 12 at close to WOT.
So to get things a little better I think I need to try the following:
1 - lower my Cold Pressure a touch - to enrichen my idle.
2 - lower my Full Throttle Enrichment Pressure. - I added some last night by drawing out the plate on the bottom of the WUR, set at 3 bar, I may have gone a touch too far.
Cheers, Chris
Old 05-01-2018, 04:14 AM
puddy's Avatar
Originally Posted by RarlyL8 View Post
The idle mixture screw is spring loaded, you must push it down (gently) to engage the receiver. Push down too far and the engine will stall. Adjustment should be CCW to rich first then CW to lean. Only a tiny adjustment should be needed if any at all.
OK, so the idle mixture is the aluminum post sticking up between the fuel distributor and the air plate. As seen in the link below? I'll check this tonight when home from work.
911 CIS Primer - Testing: Mixtures
Cheers, Chris
Old 05-01-2018, 06:28 AM
Alan L's Avatar
Yes the long pin by the air plate housing.
But do this last. Your cold idle is too lean also.
You need to measure cold pressure from your CIS gauge - pull the plug on the WUR first and pumps on. Take note of the ambient temp approx.
Not sure if you understand this yet. If you raise the WUR pressures you lean the mixture. If you are just hitting 12 AFR at top end that is OK but you can probably go bit higher - tweek Boost WUR pressure by say 0.1-0.2 bar. That should take your boost dump pressure to around 3.2 bar? You have a Leask WUR - so this is adjustable . I have not seen one - but I think you have some adjustment screws on the base of the WUR for this. That will raise your top end AFR in to the 12s. The next challenge is to eliminate the dump into the 9/10s. The only way to do this is delay the boost dump transition - via a Leask rpm switch - set to around 4500 rpm and adjust rpm range from there. So you are close, and your WUR is already set close.
Post cold pressure - that will assist with cold idle sorting. But it looks like you can richen your idle anyway - you have lean cold and hot. Insert 3mm allen key in adjuster plunger (engine running)
, depress until feel it bottom out, and turn clockwise, then release and see AFR. 1/4 turn is a big adjustment.
Regards
Alan
Old 05-01-2018, 11:44 AM
puddy's Avatar
Thanks Alan, as tested last night. CIS Pressure gauge hooked up, pumps running, WUR unplugged, trickle charger running.
Cold Pressure 1.4 bar at 60 degrees.
Warm Pressure is 3.75 bar (WUR plugged in)
I'll richen or lower pressure of my cold and warm pressures a little.
Cheers, Chris
Old 05-01-2018, 12:13 PM
Alan L's Avatar
Your CP is slightly below spec - about 0.3 bar. (rich) But your cold idle is lean. So you should probably tweek your idle mix to a richer setting - try progressive small adjustments - preferably when engine warm. You should be able to note a happy spot where idle is even and rpms pick up by 1-200. Mine idles best around 12 -12.5. Others nearer 14.
It is the boost dump pressure you need to raise a bit - that is the Leask adjustable bit. From memory you dropped from 3.75 to 3.0 bar . That dump is a bit excessive. Raise the dump pressure by 0.2-.03 bar - around 3.3. That will have the effect of raising your top end AFR also - low to mid 12s?. Then you need the Leask delay switch. Your WUR is already close to where it needs to be - minor tweek. The main issue is the boost transition - which is the universal problem with this system - the boost dump is at 3-3500 rpm. You don't need all this fuel until after mid 4000 rpm and onwards. But they had no other way of moderating it pre electronic fuel management days. Enter Leask switch.
Cruise AFR at 15 is not unusual, but this may come down slightly with idle mix adjust.
Regards
Alan
Old 05-01-2018, 12:41 PM
puddy's Avatar
Well I dicked it up. I changed my Warm Pressure .2 points and now my AFR in top end goes into 9 and has no power whatsoever ever. Gonna bring it back to where it was.
I also checked for any vacuum leaks and didn't seem to find any.
Cheers, Chris
Old 05-01-2018, 06:12 PM
Alan L's Avatar
Something not right. Changed WP or boost pressure dump? Either way, raising it by 0.2 cannot make it run pig rich. Will be more lean. Changed WP from 3.75 to 3.95 or Boost pressure from 3.0 to 3.2? The latter should make it as good as you can go with out Leask switch.
Alan
Old 05-01-2018, 06:35 PM
puddy's Avatar
I changed my Warm Pressure to 3.7 to 3.9 earlier tonight and after it was super rich. So I put it back down to 3.8. Also pulled the full throttle enchment out as far as it will go to be leaner. I was only about 1/16" out from where I left it last night. I'll drive it again tomorrow and see what happens.
My Boost pressure is about 3.4. I didn't do anything with it. The mityvac was acting weird. I would add .9 bar of Pressure but the gauge would hardly move maybe 1/2 a point. So I'd release the pressure and add .9 bar pressure again and it would jump down .4 points.
Cheers, Chris
Old 05-01-2018, 08:05 PM
Alan L's Avatar
You got some weird s..t going on there. Things should be more consistent. Whatever the inconsistency is may have given you the weird AFR last time. But raising your WP 0.2 bar will have the effect of raising the dump pressure 0.2 also. But you still have a 0.7 bar drop - which is more than spec (manual asks for 0.5). So trying to even the dump AFRs out a bit, the better option is probably to keep the WP around the upper end of range (approx 3.7-3.8) and raise the dump pressure until you have about 0.5 drop. Then see where that gets you - that takes you into the spec range for both. But to get rid of the 9/10s on boost onset, the only way thru that is a Leask sw. You want to repeat these CIS pressure readings until you get something stable, or figure out where the instability is coming from. It will reflect itself in your AFRs also.
Regards
Alan
Old 05-01-2018, 09:27 PM
puddy's Avatar
OK, so I took the car to work this morning and things are better at WOT it goes into as low as 10 but back to 11.5-12 so I don't think i'll mess with it much more than I have.
Maybe I can change my boost enrichment threshold. So if I understand the instructions properly, I should raise the threshold, which would mean I need to tighten the 3 screws in the bottom of the WUR.
If I adjust my idle mixture to make it leaner, does it make AFRs leaner higher in the rpm range too?
Cheers, Chris
Old 05-02-2018, 04:40 AM
puddy's Avatar
I went at lunch and was able to reach the WUR while it was plugged in, I turned the screw about 1/12 of a full rotation to raise pressure, so not very much, hopefully closer to what I had yesterday, I hope that make the drive home a little better for the AFR's.
Cheers, Chris
Old 05-02-2018, 10:53 AM
ECU location
sorry Puddy, I put this in the wrong post... Duh..
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 05-02-2018, 11:50 AM
Alan L's Avatar
Changing the idle AFR won't affect the WOT AFR - that adjustment is too small.
When you depress the idle adjust there is a hex head at the bottom that needs to engage , then turn the screw. You should be able to feel the hex head engage - it will engage at around the point you feel the airplate depress and AFRS change. I have heard of the very rare one where this contact point is stripped. In which case you will have no idle adjust - another issue. Have another try and see if the head will engage while loaded against the airplate pressure.
You are not adjusting the boost threshold - only a Leask sw can do that. What you are adjusting with the Leask adjustment on the WUR is the dump pressure. You need to narrow the gap between the WP and boost dump. That will help the big AFR drop at transition and lift your AFR slightly beyond 12. Sounds like you are just hitting 12. You can go a bit higher (I run 1 bar at 12.5). But as Brian said earlier - between 12.5-12 should be the aim.
Alan
Old 05-02-2018, 11:59 AM
puddy's Avatar
Thanks Alan, for adjusting the idle mixture, it seems like my biggest problem is getting an allen key that I can get inside of it as I only have about 2" clearance between the plunger and the underside of my engine compartment. Maybe i'll have to cut one down.
Cheers, Chris
Old 05-02-2018, 12:19 PM
Alan L's Avatar
No, a regular one has plenty clearance. Just insert the short end, not the long end. You will have at least 1-2"" clearance.
Alan
Old 05-02-2018, 12:24 PM
