kjchristopher's Avatar
As a note to future readers, I prefer left-handed drill bits for these occasions. They typically grab the bolt at some point in the process and back it out.
Old 04-27-2018, 07:46 PM
kevinbodman930's Avatar
I have never used any of those waxes.How did it turn out.?
Old 04-28-2018, 05:52 PM
Great idea..
This is a pic of the back side of the door striker.
Old 04-28-2018, 05:58 PM
Turbo Powered Snow Blower
Yuck Kevin! You need to color sand and wax that.
Sent from my iPhone while Driving
Derrick
Old 04-29-2018, 07:42 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Kevin's busy waxing something else, as usual!!!
Old 04-29-2018, 10:38 AM
And then... “Disaster strikes”
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 04-29-2018, 11:04 AM
Where the effffff have you been, 70'sBush?!?!
Old 04-29-2018, 11:36 AM
In 50 years of being a car enthusiast, this is the first time I have heard the phrase "detailing the door jambs".
91 535i
73 TR6
Old 04-30-2018, 05:44 AM
Mr 930XXX’s detailing OCD and overall obsession with the 930 is entertaining.
I’m not saying there’s anything wrong with it. Just a different obsession
Derrick
Old 04-30-2018, 08:11 AM
Alan L's Avatar
Most people with a 930 don't have anywhere near enough time to do that job. Too busy doing upgrades, chasing boost leaks, fixing fuel pump relays etc etc etc etc .
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-30-2018, 12:19 PM
Life got in the way of car fun for awhile but I’m back at it. I’m dropping my motor off at John Walkers next week. I’ll get it back as a long block and go from there. Hoping to be driving it again sometime mid summer. It’s been way to long.
Old 04-30-2018, 03:20 PM
Bush is definitely making a comeback.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 04-30-2018, 06:59 PM
Disaster..
I need some reference points as to what to expect and how to achieve the greatest possible level of dealing for the underside of a 930.
This process seems like it’s good.
https://petrolicious.com/articles/cleaning-a-classic-car-with-dry-ice-is-actually-a-thing
On close inspection though looks like it would need high temp pressure washing coupled with heavy degreaser before to get the desired “just rolled out of the showroom” look however.
I would like pictures of what a pristine guards red 70s 930 underside looked like. In great detail would be nice. If anyone has pics of this?
Old 05-02-2018, 06:33 AM
Disaster..
Also what was the waxoyl the factory used to protect the underside of 70s 930s?
Old 05-02-2018, 06:52 AM
Big D,If I am not mistaken it's cosmoline that you are asking about.I worked for a company installing and removing big printing equipment called Heidelberg and we used to spray all the bare metal to prevent rusting,and I would imagine Porsche doing the same,especially using the slow boat from Germany.
Old 05-03-2018, 02:01 PM
Disaster..
While restoring the suspension and brakes I found that the Krud Kutter Graffiti Remover took off all the old rattle can black and Cosmoline and left a bright white Wurth and factory overspray. It took three applications and scrubbing with a heavy brush, but it does not hurt the factory coatings.
Best part is Home Depot has it cheap.
Derrick
Old 05-03-2018, 10:04 PM
Disaster..
30 + hours into this and I have one more side to complete as it is only partly completed.
I get exhausted at times but I get a second wind similar to athletes.
Yes I know I’m missing the rubber caps that go over the door switches.
This 930 is 40 years old now.
Old 05-04-2018, 12:14 PM
Disaster..
Thanks much. I think I will to to have the entire under side pressure washed with heavy degreaser then have it cryo cleaned completely then painted and finally re waxoyl in the same method as the factory or as close as possible.
Old 05-04-2018, 12:46 PM
Originally Posted by full quack View Post
"oh the humanity"
I've been a machinist for...well...forever, and easy outs are not too effective on frozen bolts-n-screws. What you probably need here is an impact to get it spinning, and Stevie has the right idea.
Mark
I used to be a machinist too and I never had good results from easy outs.
Easier to drill off the head and use vice grips.
Old 05-08-2018, 09:02 AM
