-   -   Xdi spark plug gap? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/994906-xdi-spark-plug-gap.html)
gumba 04-27-2018 10:06 AM
Xdi spark plug gap?
Recommended spark plug for a single plug Electromotive xdi set up. Using Bosch w3cs plugs?
thanks.
Black_Hat 04-27-2018 10:34 AM
Stock Street Engine 0.045”-0.060” (1.1mm-1.5mm)
 High Performance Street 0.030”-0.035” (.75mm-.9mm)
 Alcohol High Compression 0.025” (0.65mm)
 High Power 75 -115 HP per Cylinder 0.025” (0.65mm)
 Over 115 HP per Cylinder 0.022” (0.55mm)
 Over 12:1 CR or Over 14psi Boost 0.022” (0.55mm)
http://electromotive.com/wp-content/uploads/2015/05/XDI-v1.7.pdf
GJF 04-27-2018 12:19 PM
Been running the F4CS plugs at .024. same thing as the W4CS but with the difference of having a 5/8 hex instead of a 13/16 hex. Makes it easier when changing them. More room. On your next set buy F3CS. You should be able to get away with .028 at your power level.
