16Volt's Avatar
Rarlyl8 Hooligan w/stock heatshield
Brian et all,
I am trying to get the car running again and have run into a issue with my new exhaust, the O2 sensor fouls against the heat shield. There is no way it will fit with the shield in place, do you guys normally just ditch the shield? I'd like to avoid cutting it up.
Running B&B headers with a K27/K29 hybrid hair dryer. Thanks for the help.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 05-04-2018, 06:57 AM
Jeff NJ's Avatar
I have the hooligan with a k27hfs and while it is tight, the O2 sensor does fit. Ill see if I can either find or take some pics. I would not recommend removing that shield. I would be afraid it would melt the paint on your bumper without it.
1988 930 Venetian Blue
Old 05-04-2018, 07:13 AM
Jeff NJ's Avatar
Found a pic. This is looking up from the ground. You can see my license plate on the right to help you get oriented.
I think I had to pull the bumper out to get it installed and then when I put the bumper back, it barely fit.
Old 05-04-2018, 07:30 AM
puddy's Avatar
I have no heat shield and the backside of my centre reflector and tail lights have melted a little.
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 05-04-2018, 07:36 AM
gumba's Avatar
I use heat shield cloth.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 05-04-2018, 07:38 AM
16Volt's Avatar
Thanks for the pic Jeff, looks like your shield is a bent backwards a little bit and/or your sensor is a little shorter.
Maybe I will 'massage' it a bit.
Old 05-04-2018, 07:47 AM
16Volt's Avatar
Played more with it this weekend, there's zero chance it works with an unmodified (bent or otherwise with B&B headers) heat shield. Frustrating.
I ended up finding a turbine shield which will hopefully save my bumper paint.
IMG_4742.jpg by Shannon, on Flickr
Old 05-06-2018, 07:22 PM
I guess it's a little late, but there are 90 degree adapters. I have one or two that I got for my old truck that I never used.
Old 05-07-2018, 01:24 AM
Turbo Powered Snow Blower
I would put a plug in it and add a new bung lower. If yours is at 11 O'clock now, Say 7 O'clock. If the exhaust pipe won't be in conflict crossing back across.
No one will see it.
Derrick
Old 05-07-2018, 06:33 AM
Grappler
Rodsrsr's Avatar
I ran into the same issue but had Brian relocate the 02 bung to direct it more towards the top.
Grappler
Know Gi / No Gi
1976 Turbo Coupe 3.2
2009 Carerra S 997.2 (SOLD)
Old 05-07-2018, 06:56 AM
