Question Druck Pressure Guage not working
I have a Druck Pressure gauge causing me problems on my '76 911. It was working fine and then started going above 5 as soon as I turned the key on. Last winter I sent the gauge to North Hollywood Speedo and they sent it back saying that there was no problem with the gauge. I just took the gauge to my mechanic for install and it is doing the same "top" out above 5.
So, my mechanic says it's the gauge and NHS says it's fine. Any ideas out there?
Thank you,
Dan
Old 05-04-2018, 09:46 AM
Jeff NJ's Avatar
I believe NHS. I would bet the pressure sensor on the motor is bad, or a bad connection. Most likely a bad connection between the sensor and gauge. Have you tested that?
1988 930 Venetian Blue
Old 05-04-2018, 10:59 AM
Jeff, evidently when power wire is connected to the gauge with no other connections, the gauge needle moves above 5. (I need to pull the gauge to verify, but that is what my mechanic has told me.) If this is true, what does this mean?
Old 05-04-2018, 11:08 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
When the gauge pegs with the key on (top of its range) that means you have an open circuit (broken electrical path from the sender).
First, unhook the wire from the sender and test for continuity through the sender and ground (with a multimeter) - no continuity means sender is bad (open circuit within it).
You can also then ground the removed sender signal wire to verify the gauge is working or that you do not have a short to ground somewhere else between the sender and the gauge - grounded sender wire will peg the gauge a zero. If you remove the wire from the sender and do not ground the wire end, and the gauge does not go to the top of the range, you have a short to ground in the wire someplace between the wire end and the gauge.
Old 05-04-2018, 11:19 AM
Jeff NJ's Avatar
Here is a good thread that describes your exact issue and how he solved it. For him it was the sending unit.
Oil Pressure Sending Unit Replacement
Old 05-04-2018, 11:21 AM
Thanks, guys. I'll proceed with your advice. Much appreciated.
Old 05-04-2018, 01:41 PM
mark houghton's Avatar
You need to change mechanics. He didn't even bother to consider that the sender might be the culprit. And re-installing said gauge....well now, that takes about 30 seconds at $150/hour....do the math.
Sorry, I'm out of line here. Not everyone is a DIY sort of person. It's just me....I don't have a "mechanic" and never will, mostly because I'm capable and otherwise don't trust anyone but me. I guess that makes me a narcissist.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 05-04-2018, 06:28 PM
Old car guy.....
Hot Euro's Avatar
^^^^ No, a realist
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 05-05-2018, 03:39 AM
