AutoHeat Controller - Light bulb replacement
I have the early version of the auto heat controller in my '77 turbo. It works fine, there are no footwell blowers to contend with. There appears to a light bulb (type 2721) in the unit somewhere for night time illumination. Does anyone know where it is located and if it can be replaced without removing the controller from between the seats?
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 05-07-2018, 01:08 PM
Turbo Powered Snow Blower
I have mine apart. But itís on the lift. I can look at it tomorrow night.
Iím 99% sure you have to remove it to get to the bulb.
Derrick
Old 05-07-2018, 08:39 PM
16Volt's Avatar
If you search under my username there is an extensive autoheat thread where you can see the bulb. I would just pull the unit, replace the clips for the rod ends etc.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 05-08-2018, 07:55 AM
stevie 77 930's Avatar
You'll need to pull the auto heat unit. First, you'll need to disconnect the actuating arm through the side access door.
or remover the passenger's seat to access the the bulb through the access door.
1983 911SC
1974 914
2018 GTS
2019 Audi S4
'76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 05-08-2018, 08:08 AM
Guys,
Thanks for your replies. I will likely have to bite the bullet and remove the unit for bulb access.
-Dennis
Old 05-08-2018, 08:35 AM
