-   -   Dumb wastegate question (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/996942-dumb-wastegate-question.html)
Rich76_911s 05-18-2018 12:15 PM
I feel like an idiot asking this, but what are the advantages of switching to a non-stock wastegate IE tial?
xbmwguy 05-18-2018 01:52 PM
BLING and probably more options for spring rates
'76 911S 3.0 05-18-2018 02:06 PM
Easier to find replacement parts down the line too
Tonger 05-18-2018 06:56 PM
Less weight, smaller package, larger diaphragm with less boost creep, and tunability.
pkabush 05-18-2018 10:41 PM
I switched to a Tial when mine developed a leak. While it is true that its smaller and it does weigh quite a bit less than the original, there are no performance gains to be had by switching.
I’d look for other areas to improve on. Unless you have existing issues with your waste gate or you need to change the spring rate.
Rich76_911s 05-19-2018 05:31 AM
Thanks guys.
I was just curious about why people do it.
spuggy 05-24-2018 04:31 PM
I switched from the factory wastegate because the G50 conversion pushed the motor back just far enough that the headers wouldn't let the factory item clear the body (930 transplant, 911 shell).
Tial F46 was the easy fix for me; bolt-on replacement, fitted into the space available.
But rebuildable, made from better material, more spring choices, smaller, lighter, cool colors- those are all good reasons too :)
Ddin't realize the F46 was originally made for the 962, that's kinda cool too http://tialsport.com/index.php/tial-products/wastegates/42-f46]TiAL Sport - F46
Ken911 05-24-2018 05:33 PM
Turbo smart makes really good waste gates and bovs
slow&rusty 05-25-2018 05:03 AM
Buy this guy some vacuum hose, he nailed it!
1979-930 05-25-2018 06:00 AM
^^^ Make sure it’s Silicone hose. [emoji6]
