How low CP can i go?
i am tuning a 964c2 turbo with frankencis and right now use adjustble wur.
how low could i go with CP for geting max fuel out of it? right now i have CP aprox 2,2-2,5 bar at 5000rpm and above and that gives AFR 12.1 |
So you are just running FCIS controlling the Lambda valve and leaving the WUR to set the CP? Why not switch to the eWUR block and let FCIS control the CP too?
I have the frankencis ewur block to but i had some problems so i want to make it run
fine with adjustble Bosch wur and frankencis kontroling the lamdavalve first. After that i want to test with the ewur block again |
| All times are GMT -8. The time now is 03:43 AM. |
