-   -   Necessary to remove both wrist pin circlips for piston removal? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1001612-necessary-remove-both-wrist-pin-circlips-piston-removal.html)
Dauner 07-07-2018 07:27 AM
Hi everyone,
I've been mostly posting in Technical Forum, but may switch to this one. Not sure of protocol. Assume mostly same people? Car is 1989 911 Carrera 3.2 with 200+K miles. Tearing down for a rebuild. Sending cylinders out for bore out to 3.4 and coating, and buying new pistons.
I have engine disassembled down to point of piston removal. Question is, do I need to remove BOTH circlips to get wrist pin to point of piston removal, or just 1? Everywhere I read in formal texts (Wayne's book and Bentley), it says remove circlips in plural. If it's not necessary, why take the chance of damaging a piston during prying/pulling of circlip out?
Does it matter which circlip I remove and which way I press the wrist pin? One side is deeper to circlip than the other. Planning to start with piston 1 per Bentley, and press toward flywheel end. If authorized, I'd only remove the clip on flywheel side.
Also, per forums, planning on just using screwdriver handle as a drift. OK?
Thanks!
Mark
175K911 07-07-2018 08:10 AM
You only need to remove one circlip. Then tap the pin out that side.
Dauner 07-07-2018 09:02 AM
Excellent. Thank You!
Eagledriver 07-07-2018 11:44 AM
Heat the piston slightly with a heat gun or propane torch, the pins will slide right out.
-Andy
Dauner 07-07-2018 06:10 PM
Thanks Eagledriver. Too late, already tapped them out with the screwdriver handle. Didn't really require much. I do have to admit that I was mildly concerned with the load on the rod bearings in an axis that they were never intended to see. If I had to do more than a tap tap, I'd have tried to figure out a way to hold the rod.
Next step, splitting the case. All uncharted territory for me...
Thanks again,
Mark
Jeff Alton 07-08-2018 06:52 PM
The 3.2 pins always slip out easy, while some 3.0 pins can be stubborn and require a touch of heat...
rxtrom 07-09-2018 04:40 AM
Thanks again,
Mark
Don't forget the "hidden bolts" in the chain through-way and the 3 behind the flywheel which needs to come off.
Drbraunsr 07-09-2018 08:24 PM
Buy Wayne's book: How to Rebuild and Modify Porsche 911 Engines.
Best $30 you'll spend on your rebuild. Especially if it's your first....
There's a complete section on dis-assembly
Jeff Alton 07-09-2018 08:30 PM
Great book. Good resource.
But, research some of the assembly techniques (sealing things up) before assembling your engine.
Cheers
