Mag case in hot tank > no go?
Hi, ive read somewhere not to put mag case (2.7 7R that is) in hot tank. My machine shop said they could lower the temperature of his jet/washer hot tank to minimal.
Is there any danger? What should be the temp? Any other way apart elbow grease? Thanks to all. |
That depends on the chemicals used in the hot tank. Some will dissolve Al and Mag parts. If the tank uses water based solvents its probably not a problem. If there is any doubt put a scrap Aluminum part in the hot tank overnight. If its still there the next day and it isn't etched or otherwise visually affected its ok to use.
