-   -   Bead blastihg the cases and cyl. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/100303-bead-blastihg-cases-cyl.html)
Joe Davis 03-02-2003 09:49 AM
I've just sent my heads out to be cleaned
I was wondering if its safe to bead blast the cases and the fins on the cly.?
thanks
Joe
ChrisBennet 03-02-2003 12:44 PM
I would not bead blast the case or camshaft housings with anything. They contain oil passages which would be hard to clean.
-Chris
snowman 03-03-2003 01:07 PM
certain to cause engine failure in the near future. No known way to clean all the beads out.
cstreit 03-03-2003 07:03 PM
Dipped or nothing... DOn't get it blasted... Would you be willing to risk a bead jamming up a piston squirter or oil passage?
