JoeMag's Avatar
Level in oil tank
Gents -- Where is the oil level in the tank when it's considered full? ...usual settings: engine running, normal op temps, etc
Old 07-25-2018, 11:53 AM
Just over half way in the tank at operating temp.
The 10 qts expands about 2 quarts between cold and hot.
Bruce
Old 07-25-2018, 12:53 PM
JoeMag's Avatar
Thanks Bruce... are you saying there's about 10 qtz in tank when it's "full"?
Old 07-26-2018, 12:58 PM
The usual oil change is about 10 qts
Draining, you have a couple in the engine case and the restin the tank.
Nothing gets back from,the thermostat from the front cooler.
Bruce
Old 07-26-2018, 03:16 PM
kjchristopher's Avatar
No, he's saying
and pointing out that
to emphasis why he qualifies his answer with "at operating temperature"
Old 07-26-2018, 05:07 PM
