Valve Spring Compressor for 964
I’m onto my second rebuild and this time I will do the heads (last time was essentially a reseal as the top end had already been done).
What size valve spring compressor tool should I order? Are there any size constraints, features etc required or will a generic size fit? This won’t be used often as I expect two rebuilds will be my limit so I don’t want to go crazy prices if I can avoid it. TIA |
I use my same one for the 911 heads
Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 12:19 PM. |
