-   -   3.2SS MFI build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1005121-3-2ss-mfi-build.html)
BURN-BROS 08-16-2018 09:25 AM
3.2SS MFI build
Salutations all...
We just completed this Gem for a client. It's slated for a 1970 lightweight.
Specs.
83SC core.
98 x 70.4
38mm intake port stock exhaust.
9.5/1
DC40 Dougherty Racing Cams
1970 911 E injection bored out. 46 air horn 41mm throttle plates 38mm port (Burnham Performance)
New style Polyamid lines. (bigger diameter than current offerings) (Burnham Performance)
Burnham Performance Re-curved stock dizzy (Mod RS)
SSI
large single out muffler.
Engine was backdated some to look appropriate in the engine bay, but not 100%
The specs are identical to Walker's STR2 with the exception of muffler and the year of the MFI induction.
http://forums.pelicanparts.com/uploa...1534432881.jpg
http://forums.pelicanparts.com/uploa...1534433010.jpg
http://forums.pelicanparts.com/uploa...1534433048.jpg
http://forums.pelicanparts.com/uploa...1534433088.jpg
http://forums.pelicanparts.com/uploa...1534433197.jpg
lvporschepilot 08-16-2018 10:25 AM
Love it. Good for say 265-275bhp? thanks for posting
BURN-BROS 08-16-2018 04:00 PM
Yes Sir. With the right exhaust it will pull to 7500 redline.
icarp 08-16-2018 04:45 PM
Very nice , any reason for not using the DC60 cam ?
tastefully done
TurboKraft 08-16-2018 05:27 PM
Beautiful workmanship, Aaron!
Geronimo 08-16-2018 05:32 PM
Very nice, i'm wondering and trying to learn.
I have been thinking about a 3.2SS build in the future for my 3.0SC. Currently running 46mm PMO carbs, and SSI's. Was hoping I could get something in the 250WHP range will the PMO be a help or hurt in this endeavor?
Also thought I might change out the SSI's for slightly larger headers and M&K 2into2 gt3 muffler.
Thanks for the help guys.
BURN-BROS 08-17-2018 07:47 AM
tastefully done
Budget, port size and exhaust. Anything above a DC40 I want to use a Carrillo. I open up both intake and exhaust further when using a DC60 or greater. Exhaust primary and muffler needs less restriction.
Thanks you Sir!
250hp is easily achievable with the build you stated.
SSI is good for 250 and as long as the M&K des not restrict, you should be good to go.
lvporschepilot 08-17-2018 11:16 AM
Those are good words to live by here. Balance all rotating components and use much stronger and lighter rods when seeing above 7k regularly.
Geronimo 08-17-2018 03:58 PM
DO I dare ask.... is a 12k-15k budget reasonable for a solid 3.2SS build? I just got my SC and want to plan ahead. Currently have a good running 3.0 with 110K miles, running 46mm PMO and SSI currently.
Figured I could do a rebuild in 2-3 years.... but I see people dropping huge $$$ am I in the price range or way out of sorts?
BURN-BROS 08-18-2018 09:02 AM
That depends. If you are building a very mild engine, there is no advantage other than a small increase in displacement. If you are planning 90-100 hp per liter the displacement bump becomes more meaningful.
The budget you have wont go far and you might be disappointed with the results.
Geronimo 08-18-2018 02:26 PM
If I can't get 250-260WHP for 12-15K I swear i'm buying a Vette and leaving Porsche to the rich folks.
al lkosmal 08-18-2018 07:39 PM
Aaron..that is beautiful...a work of art.
regards,
al
jpnovak 08-18-2018 10:33 PM
Nicely Done Aaron. As always.
BURN-BROS 08-19-2018 07:45 AM
Thanks Guys!
budge96 08-28-2018 10:01 PM
Lookin ' good Aaron ! Very nice ! Bert
Carbster09 08-29-2018 10:37 AM
Looks like someone will be 'vette shopping! I hate the Porsche "tax", but my old 'vette sits when I drive my old Porsches, so go figure!
BTW if you want a 500hp Big Block 'vette I might make you a deal! 1971 LS-5, very original but with more power, suspension and brakes!
