-   -   Extra oil hole under bearing?! Or is this standard? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1006009-extra-oil-hole-under-bearing-standard.html)
Adrock 08-26-2018 01:08 AM
Removed my bearings today and found and extra hole under my third or fourth bearing (sorry have forgotten already!) on oil cooler side of case. It's a 3.0 SC 930 case.
It looks like an actual oil hole. I couldn't tell where it went or if it was infact all the way through. Could it just be a casting fault? It doesn't appear that it's caused any bearing issue on the back of the bearing. These appear to be the original 1983 bearings.
I would note that next to this bearing it looks like something has given way at some point in the case. See the photo with the gouges in the case. https://uploads.tapatalk-cdn.com/201...8caddcc277.jpghttps://uploads.tapatalk-cdn.com/201...a04f65c282.jpghttps://uploads.tapatalk-cdn.com/201...1b92189ff0.jpghttps://uploads.tapatalk-cdn.com/201...d292f0e6d7.jpg
Sent from my Pixel 2 using Tapatalk
Adrock 08-28-2018 07:18 PM
Still looking for ideas as to why this hole is here...
There is staining on the bearing where the hole is - the same as where the stock hole is... I'm assuming oil is getting through.
My two ideas are that it's either been drilled previously (which seems unlikely as it's not really a neat hole and WHY?) or it's a engine case casting defect.
If it's been there since new, I'm guessing no intervention is required... however could this somehow affect oil pressure if oil is infact flowing through?
Eagledriver 08-28-2018 08:48 PM
I agree with you that it’s probably a defect in the case. My initial thought was that the oil pressure in there could cause a problem, but I don’t think so. There’s oil pressure on the backside of the bearing already due to the main oil hole. I would just ignore it and build the engine as normal.
-Andy
Robert Espeseth 08-29-2018 02:26 AM
"Cross-drilled crank" modification done?
Adrock 09-03-2018 10:43 PM
I didn't look specifically, but I don't think i noticed it.
Pretty strange spot for a defect. I'm surprised something like that would get past Porsche quality control when they inspect the cases. Pretty obvious!
itsme 09-04-2018 11:57 AM
If your talking about the spec under the oil hole then yes that looks like a casting defect. Some oil got under it and tinted the bearing. Nothing to worry about. Stick a pin in it and check the depth. If its shallow, which it looks like its nothing to worry about.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
