-   -   Just spitballin' - 3.6 plenum fit to 3.2/3.3 heads? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1006150-just-spitballin-3-6-plenum-fit-3-2-3-3-heads.html)
spuggy 08-27-2018 04:54 PM
Hey,
Just wondering; does a 964/993 plenum line up with the ports on a 3.3 motor, or is there a difference in port-to-port spacing between 1-2-3 on the same bank?
Looks to be pretty trivial to deal with bank-to-bank spacing, if that's different...
Thanks in advance!
Tippy 08-27-2018 07:26 PM
They’re the same
oh snap 08-27-2018 09:19 PM
I think you just need adapters for the studs. I think rothsport makes them
Evan Fullerton 08-27-2018 09:41 PM
Clewett makes some or TurboKraft can make them from their 930 aluminum EFI injector blocks. That's the route I went to get a proper taper from the ~42mm VRam intake runner ID down to the 39MM big port SC head size.
Steam Driver 08-28-2018 03:16 AM
PM me.
spuggy 08-28-2018 09:05 AM
Cool, thanks guys!
Had hoped it'd be that simple, but wasn't that hopeful...
Was looking at some of these (well, actually, a GT3 RS intake plenum caught my eye first), noticed ends obviously intended to fit straight onto ITBs and thought "hmmmm",
Then, not actually having $4K lying around for a rare carbon fibre motorsport part, I looked at some 964 manifolds and thought "gee, these look functionally identical - but much cheaper...", and "be pretty easy to connect the intercooler outlet to where the throttle body used to bolt on"... :)
I'm leaning towards alloy over plastic - other than weight, any reason to prefer the plastic ones?
Steve@Rennsport 08-28-2018 09:13 AM
The GT3 plenum is too big for a 3.0-3.3 and N/A engines will lose a lot of low & mid-range power unless ITB's are installed under the plenum. This one is best suited for 3.5 & larger.
The late 964/early 993 plastic ones can be made to work, however you will lose some low end power (unless ITB's are used under the plenum for N/A applications).
For turbo motors, its a nice upgrade when bigger cams are used. :)
Tippy 08-28-2018 09:22 AM
Apparently, the plastic ones flow more evenly from runner to runner.
I have an aluminum set if that is not a super concern for sale. It does not have a center section or any other supporting parts. It's just the manifold halves.
Steve@Rennsport 08-28-2018 04:38 PM
True, but aluminum ones may be Extrude-Honed for effect.
spuggy 08-29-2018 10:26 AM
OK, I probably shouldn't be too coy about why I'm asking, 'coz guys are guessing :D
Car's a Motec 3.4 930, 8:1, heads ported to match 3.2 manifold(s) and SC cams. Runs great. Throttle response totally unlike CIS...
However, distance from the throttle butterfly to the valves is still ~2 feet; ITBs would seem ideal to further improve throttle response low speed/off-boost.
964 manifolds look like a laughably easy route; drop them on top of ITBs, the intercooler outlet->plenum joint is one fitting, one bend and a straight shot to the manifold throttle body flange...
Or am I missing something obvious?
Tippy 08-29-2018 11:11 AM
Exactly what I am going to do. Read my sig.
The 964 intake couples to ITB's with a simple silicone coupler and hose clamp.
sp_cs 08-29-2018 02:06 PM
I’ve have done similar recently using 993 intake and ATPower ITBs - more work still needed due to failed valve stem seals, but runs pretty well. Looking to use the opportunity to increase the CR with new JEs:
http://forums.pelicanparts.com/uploa...1535576555.jpg
ChrisBennet 09-23-2018 07:53 PM
I don’t see a distributor. What sort of EFI setup are you running? (If it’s not a secret I mean.)
sp_cs 09-24-2018 12:22 AM
Motec m84, Audi COP
clutch-monkey 09-24-2018 04:05 AM
what's the advantage of running a system like this instead of trumpets?
sp_cs 09-24-2018 06:10 AM
Torque is meant to be the primary benefit - i’ve read that the plenum provides a ready (pre-collected) dollop of air to expedite/improve combustion and sharpen throttle response.
William Knight mentioned to me that a common plenum will always provide more area under the torque curve than straight stacks.
clutch-monkey 09-24-2018 02:57 PM
interesting. i have CNC'd mounts for the plenum but my tuner prefers the trumpets (perhaps for setup). i may look at doing back to back dyno tests down the line.
sp_cs 09-25-2018 12:38 AM
The atPowers leave you with stubs so relatively easy to mount the plenum with use of silicone connectors.
http://forums.pelicanparts.com/uploa...1537861049.jpg
