hipdoc's Avatar
Porsche Crest 993 head studs
I'm using the 993 head studs on my 2.7L 911 engine that has 11:1 JE pistons. I see that the 933 torque specs show that they're stretch bolts that are:
First stage: 20Nm (15ftlb.)
Final stage: 1 x 90° +- 2° rotating angle
Does anyone know what head nut torque I should use for my 2.7L engine application?
Would that be too tight for my engine case and cylinders? My case has Case Savers.
Thanks,
Hipdoc
Old 09-26-2018, 11:15 PM
That’s the same spec for a 3.2 Carrera
Seems tight for a magnesium case where the cylinder expansion and dilivar expansion is near the same.
The mag case spec was always 25 ft#.
Bruce
Old 09-27-2018, 04:02 AM
