-   -   The simplicity of the air engines (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1008565-simplicity-air-engines.html)
Neil Harvey 09-22-2018 07:41 PM
I come to love these early engines as they are so much simpler to the later water engines. They are engineered to a higher standard, even though they are many years old. The new engines are a lot more complicated and when something goes wrong, it hurts your brain trying to figure out what!!!
We are going back into the older engines and have many new parts under development. Our core business is designing and manufacturing our own parts for any engine we build, "hot rod" or just plain mess with. This is not limited to Porsche and not just about "hot rodding".
The most recent development was with the 991.1 GT3 engine that has a major fault with the valve train. We designed and developed our own "solid" version of the valve train, eliminating the hydraulic system that proved so troublesome. This is our wheel house of work we do each day. Now we are focusing on the earlier air cooled engines so that this technology can be offered to these early amazing engines.
I will post more updates on what is coming as we get further into the projects. I can say that there is a 4 cam air cooled center plug, small chamber 2V cylinder head, cam housing with finger follower valve actuation coming. 1st article prototype parts are in the first stages of machining now.
Here is the final assembled GT3 cylinder head with the PD solid fingers fitted the 991.1 cylinder head. This shows the level of work we do and what the quality of the 911 air parts coming will be. http://forums.pelicanparts.com/uploa...1537670483.jpg
ChrisBennet 09-23-2018 07:45 PM
Sweet! I’m so glad you take the time to post here.
BadToTheBown 11-01-2020 07:45 PM
Originally Posted by Neil Harvey (Post 10191698)
... designed and developed our own "solid" version of the valve train, ...Now we are focusing on the earlier air cooled engines so that this technology can be offered to these early amazing engines...a 4 cam air cooled center plug, small chamber 2V cylinder head, cam housing with finger follower valve actuation coming...Here is the final assembled GT3 cylinder head with the PD solid fingers fitted the 991.1 cylinder head.http://forums.pelicanparts.com/uploa...1537670483.jpg
Thank you for posting Neil, genuinely enjoying reading your posts...question, what keeps you from doing a 4-valve air cooled head leveraging your water cooled head work?
Neil Harvey 11-02-2020 09:04 AM
We tried years ago and failed miserably. Just not enough real estate to have 4 valves, a center plug and enough cooling.
I believe this has been achieved recently but required additional "oil cooling". Don't understand the reasoning of this when there is proven 4V heads cooled by water.
Certainly not for the faint of heart.
nh
Mad Max 11-02-2020 10:10 AM
I am liking the idea. Hopeful it comes to fruition.
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
brighton911 11-02-2020 10:12 AM
Very nice Neil but then again, that is the norm for goodies from your shop. I take it lash adjustments by stem caps?
BadToTheBown 11-02-2020 08:50 PM
OK, I guess I made an assumption that the newer water cooled engines length and proportions were very close the air cooled, thanx...
I'd be interested in knowing more about this oil cooled 4V, I know I don't want water cooling for an air cooled build, although I've seen pics of someone putting a water head on an air cooled lower...
Thanx for the follow-up...
winders 11-02-2020 09:12 PM
No one has been successful building 4 valve heads for an air-cooled 911 engine without water cooling them. I define successful as being as durable and reliable as 2 valve heads.
smokintr6 11-03-2020 08:33 AM
Well, I doubt anyone that owns one of the 4 valve Singer/Williams engines will be interested in letting us find out if that's the case.
winders 11-03-2020 09:56 AM
I don't think anyone is close to saying that the Singer/Williams 4V heads heads experiment has been a success...especially when using the definition of success I gave previously.
smokintr6 11-03-2020 10:00 AM
and you will never know...
