-   -   Upside (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1008593-upside.html)
Billthebuilder 09-23-2018 06:58 AM
Upside
New rebuild! it appears I installed the Pistons upside down. Should I just rotate them or pull them out of the cylinders and start over with the proper ring orientation. :confused:
Flat6pac 09-23-2018 10:46 AM
Ring orientation doesn’t matter as they will move to their desired location almost immediately.
Bruce
Billthebuilder 09-24-2018 12:21 PM
So I'm going to remove the clips and piston pins and rotate piston in the cylinder 180 and reinstall pin and clip does that sound right ?
Catorce 09-24-2018 12:30 PM
IMHO Ring orientation does matter; on the flat 6 motor you never want ring gaps pointed straight downward as that contributes to even more oil pooling in the cylinders when left for a long time, and even more smoke than usual on startup.
Steve@Rennsport 09-24-2018 01:40 PM
If your engine uses offset piston pins, you really need to R&I them correctly.
Billthebuilder 09-24-2018 04:52 PM
1977 2.7 cis engine with euro Pistons I don't think they are offset. If I pull the piston out will I damage the rings or is there a trick involved? I hate to buy new rings they were hard to fit and required a different size for the center gap!
