-   -   Right way up? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1009205-right-way-up.html)
Targatogo 10-01-2018 07:51 AM
Right way up?
Hi - can you advise me please? The circular head gaskets - is there a right way to fit them? The gasket has a flat side - should this be on the crankcase side? Should have said '82 911 SC - no details in Bentleys about a right way up!
Many thanks,
KTL 10-02-2018 03:01 PM
Flat side faces outward to seal against the machined surface of the head.
Targatogo 10-03-2018 08:46 AM
Thank you so much for your reply - I have posted in several places and had little feedback on this question. I will pass this onto the engineer.
Determined 10-17-2018 02:04 AM
Correct
