Smart quod bastardus
fredmeister's Avatar
FOR SALE-set of 98mm JE pistons for 3.4 liter turbo
For sale a brand new in box set of 98mm 3.3/3.4 liter pistons from JE:
7.5 to 1 compression 98mm set for a 3.4 liter conversion --ONLY 3 pistons, wrist pins, snap rings and piston rings
I originally ordered a replacement from JE for three damaged pistons during my initial rebuild but then decided to order a complete set of Mahles after having already received these. You can order another three through JE to make a complete set of six very easily if you want a complete set for one engine. its easy to order off the item number and build sheet I can provide for you.
Specs are as follows:
machined valve relief pockets in dome allow radical cam to be used
98 mm bore with 23mm piston pin and wire lock snap rings
special ring package with chrome top ring ---1.2x1.5x4.0 ring grooves
custom machined relief groove in between first and second ring land for anti detonation relief.
special coated skirts for friction reduction anti galling during run in
Looking to get half or more back what I paid for these. Asking $500 or best offer.
PM me for more info.
thanks,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-23-2018, 06:38 AM
Bump for April....make me a reasonable offer.
Old 04-04-2018, 06:41 AM
Still for sale.
Will take $450 or reasonable offers. Contact me via PM.
thanks,
Fred
Old 08-07-2018, 07:27 AM
Bump
Old 08-15-2018, 02:25 PM
sp_cs's Avatar
might be worth reposting in the classifieds section
Porsche 911 Used Parts For Sale & Wanted - Pelican Parts Forums
Shirish
1987 Carrera, Granite Green
Old 08-15-2018, 02:42 PM
Its already posted there.
Fred
Old 08-27-2018, 06:06 AM
Bump price reduced will take $450
Fredmeister
Old 09-21-2018, 11:30 AM
Bump again.
Old 10-22-2018, 02:43 PM
