-   -   Correct order for connecting rods on crank shaft? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1012155-correct-order-connecting-rods-crank-shaft.html)
Alan L 02-19-2020 09:53 AM
I think the plan is - if you are starting from scratch, you can weight them in pairs 1-3, 2-5,4-6 with the heaviest pair at the flywheel end - from memory.
Alan
