Web Cam 05-302 40i/40e
I'm scratching my head. Ordered a 964 cam for my 78 3.0. and received from WEB what appears to be the correct number 05-302, web site confirms it, but the parts sure aren't the same. What am I missing?
The cam I pulled is on the top, new one on the bottom. Tks http://forums.pelicanparts.com/uploa...1542076157.jpg |
I think if you ordered a camshaft on a new cam core the only ones currently available are the later design. So you will need the bolts and washers and you will have to order them from the Porsche Dealer you will still be able to use the same parts behind the sprocket.
Yes, I ordered new, new camshaft, new core. I didn't realize there are additional parts to convert to my design.
| All times are GMT -8. The time now is 09:16 PM. |
