-   -   Titanium Hardware (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1013357-titanium-hardware.html)
DSPTurtle 11-17-2018 08:36 AM
Titanium Hardware
Hi Guys,
Does anyone have a good source for reasonably priced Titanium fasteners? I'm mainly looking for the M6 bolts for all the engine tins. That's just wasted weight...LOL M6 1.0x10mm.
chrismorse 11-17-2018 11:17 AM
McMaster-Carr??
These guys have an enormous selection of fasteners, materials and tools, ship quickly and are nicely priced.
Give them a shot.
Chris
DSPTurtle 11-17-2018 11:20 AM
Thanks man. We have an account with them but they are not very competitively priced...
Give them a shot.
Chris
Walt Fricke 11-17-2018 04:37 PM
Have you calculated the weight savings? Care to share?
Me, I once figured I should saw off the end of every bolt or stud which extended beyond its nut. So far, it is just a thought.
dap930 11-18-2018 08:41 AM
Amorbolt.com has a M6 x 10mm for $3.25ea. The description does not specify the thread pitch, but it is probably 1.0.
DSPTurtle 11-19-2018 02:54 AM
I hadn't gotten that far yet since my first google results yielded the bolts being about $5 each. I estimate them at about 5 grams each not including the washer. Ti is about half the weight. I have not found any Ti washers as of yet. I think there a roughly 36 M6x10mm fasteners by the time you do all of the engine tins. So overall, it's probably about 100 grams. Since I have gone with an amber f/g tin kit for this R&D motor, I thought it would be a nice touch... at $1 per bolt. Certainly not worth $150! Although I have dropped $150 on less practical items :eek:
I'd be much better served tossing a pair of Mg chain boxes on there and call it "lightweight" :D
The Pauter rods already eclipse that weight savings...
Walt Fricke 11-19-2018 03:27 PM
Are alu washers lighter than the steel washers Porsche uses for the shroud fasteners? They should work fine on the shroud. Or could Ti washers end up being even lighter?
All three of my sand cast case 2.7/2.8s have the mag chain housings and covers (or are the covers from the tensioner kits aluminum?). And a mag case vent cover.
Turns out the early two bolt alternator/fan housing strap weighs the same stock as the later one bolt strap full of holes, so I now use the early one with holes. It never ends.
DSPTurtle 11-20-2018 07:27 AM
Ti is heavier than Al. But Ti has the same strength as steel. However, now you've got me thinking that cheap aluminum bolts should be perfectly sufficient for holding all of the cooling tins to the motor. Hmm... back to the drawing board on the weight savings since Al is about 50% of the weight of steel. :)
Ken911 11-20-2018 10:29 AM
You know if you just start hitting the gym you'll lose more weight than any you might save with titanium bolts!!!!
Tippy 11-20-2018 12:02 PM
I’d worry the aluminum bolts will break with vibration
DSPTurtle 11-20-2018 06:53 PM
I don’t think you’d be that worried. There are at least three fasteners for each critical joint. So it would be hard to miss if they started to fail.
DSPTurtle 11-20-2018 06:55 PM
That’s an enormous understatement. But that Ti is so very sexy.
Ken911 11-20-2018 06:55 PM
Lol
gtc 11-21-2018 01:20 PM
Originally Posted by DSPTurtle (Post 10257869)
...Ti has the same strength as steel.
Not true, but whatevs.
Try ebay or aliexpress. There are lots of options out there marketed to bicyclists.
Here's one example:
https://www.aliexpress.com/item/Titanium-screws-M6X10-DIN-84/1698845471.html
Walt Fricke 11-21-2018 11:49 PM
Aluminum has to be plenty strong for this application. Plastic would be lighter yet, and probably strong enough. There are more of these fastener than you really need for the shroud.
The surrounding tin - if you are going to keep it - is another story - lots of moving around there. But I bet you have replaced that with something lighter. On my GT car I made it out of aluminum. The front (of the car) part sheet metal is screwed on normally more or less. The rear part is held to the rear of the case in more or less the usual way. On each side there is an aluminum strip bolted to the case, and the rest out to the side rails is Dzused to the fixed part. All this was done to speed up the R&R, but some weight was saved. The regular short 6mm bolts holding the rear piece on have tended not to stay in place, but the whole rear piece stays put anyway because it is held by the Dzuses on each side.
Spenny_b 11-22-2018 01:50 AM
Drill out the centre of each steel bolt, ie., hollow-out the threaded portion...then re-plate them. Far cheaper (Ok, not as sexy as Ti, but...)
You need to read "proffighter" build thread (Another Rust Combat ) for this sort if silliness, lol! If you stand still for long enough, he'll drill your feet for "lightness", haha.
proffighter 11-22-2018 04:11 AM
Hell YeahSmileWavy
TZ 197 11-22-2018 10:18 AM
Toronto cycles dot com website has pretty good pricing on nice metric hardware mostly 6al/4v although you could use a lesser grade for the shrouds. They also stock ti washers if you really gotta feel it.
If you catch it right short 6mm bolts can be had on ebay for $1 ea in bulk. I have used these budget ti bolts for years on race motorcycles with zero issues.
Spenny_b 11-24-2018 03:10 PM
Originally Posted by proffighter (Post 10259810)
Hell YeahSmileWavy
Hahaha! Hey you mad Swissman!! You doing well I hope?
Long time since a build thread update?
S
911pcars 11-26-2018 01:14 AM
A reduction in vehicle weight should be measured in ounces, not grams.
1 oz = 28.3 grams
Replacing steel fasteners with Ti versions is for those with burgeoning DIY budgets and or bragging rights, and best suited for cycle weenies where weight savings can make a difference. Spend your money elsewhere for more effect.
FAQLoad - Bolt Tuning - replacing heavy steel bolts with titanium, aluminum and carbon fiber
Sherwood
DSPTurtle 11-26-2018 06:02 AM
1 oz = 28.3 grams
Sherwood
Bragging rights it is. Those carbon bolts sound epic!
http://forums.pelicanparts.com/uploa...1543240794.jpg
Tippy 11-26-2018 06:52 AM
Nylon:
https://www.mcmaster.com/standard-hex-head-screws
911 tweaks 11-26-2018 03:54 PM
+1 what Sherwood says....
If you are doing this for appearance that’s fine and a lot more cost effective to replate the hardware in finish of your choice and retain strong steel hdwr.
IF trying to reduce car weight, TONS of places to do and a lot more cost effectively achieve such...
Have fun... many ways to skin the cat you seek to do
KTL 11-28-2018 07:29 AM
As long as you're chasing weight loss on the engine, get yourself a magnesium case breather cover and magnesium upper valve covers? The upper valve covers will typically require some flattening on the grinder table..........
Don't forget to use some M8 titanium nuts on the valve covers and engine case peripheral studs?
DSPTurtle 11-28-2018 06:19 PM
The amber tins save about 2.6 pounds, or 41.6 ounces, or 1,179.43 grams. The Ti bolts that someone emailed me a link to should be a nice touch.
Discseven 12-04-2018 09:19 AM
Originally Posted by DSPTurtle (Post 10256348)
...Although I have dropped $150 on less practical items :eek:
To your candor JB http://forums.pelicanparts.com/support/smileys/wat6.gif
DSPTurtle 12-21-2018 07:35 AM
My Ti fasteners finally showed up from who knows where. I had a chance to weigh them to get actual numbers. I used the normal steel washers for the comparison since they are under 1g each. They are about 1/3 the weight of the typical steel fastener. So about 1/3 of a pound when you combine all 39 of the M6x10mm pieces. Is the juice worth the squeeze, YMMV http://forums.pelicanparts.com/suppo...ool_shades.gif
http://forums.pelicanparts.com/uploa...1545405538.jpg
http://forums.pelicanparts.com/uploa...1545406426.jpg
DSPTurtle 01-19-2019 10:19 AM
I'm back... with more data.
I'm not sure who mentioned nylon fasteners but... thank you. They are .5g each. So I am going to run them in a few areas for a few weeks and see how they hold up. I have some concerns about the heat having a negative effect but they definitely are significantly lower weight. And as an added benefit, they won't rust! This pic is the equivalent number of fasteners while maintaining the same weight...
http://forums.pelicanparts.com/uploa...1547921865.jpg
75 911s 01-25-2019 05:49 AM
Hey how'd the nylon fasteners work out?
