1969 911T: What tube should go here?
Hi guys
After years in restoration I am soon to assemble everything back together. However, I simply don’t remember what tube should go into this place (marked in red in the attached picture). Help would be appreciated :-) Cheers Mikael |
My friends call me Phish
That is a pre heat hose from the heater box from inside the car. On 912's it connects to the back of the T- Bar on top of the fan shroud. I believe that 911's hook up at the end of the air filter's snorkle.
Thanks for the quick reply.
Since I will be running EFI and no heat exchangers I guess I might as well cut it off or just plug it. Cheers Mikael |
