Just confirmed with Pauter---they'll rifle custom rods for this build. Am researching force of rod movement to see if there's any reason to avoid passing oil through inside of rod. No conclusion yet. Looked through JE ref/link you provided/TY Kev. Those pin lube solutions are now included on piston design sheet. Idea for FPL via inside of rod is to deliver pressurized oil directly to bushed pin area. Pauter mentioned placing circumferential groove in bushing at feed point in order to reservoir oil in bushing. I've read info about hatching bushings and journals for directional oil control. More research needed. Cross drilling main and obviously drilling journals is planned. Provided riffled FPL is done, and given your input, plan now is to up squirter to 1.5mm rather than 2mm. And swap existing oil pump for larger unit---appreciate specifics on squirters and pumps. Adding oil passages and changing squirters obviously alters oil flow dynamics. Adding oil pressure sensors along with ability to---after all's said & done---adjust and set (balance) oil distribution throughout engine is now obligatory. Where sensor and control points would be need to be determined. Custom piston and rod solutions are heading in positive direction. No obstacles encountered yet. Budget remains in order. Having gotten immersed in rod and piston research, zero progress has been made concerning EFI (Megasquirt) over the last few days. |
Carillo does bore rods for FPL. Called Carillo... is $90 surcharge per rod. With build-plan being to use minimum mass rods, placing this oil channel requires mass to be added back into rod to accommodate bore. Estimate is +30-35 gms per rod.
<iframe width="560" height="315" src="https://www.youtube.com/embed/lBb1ZDGXmBs" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
I wonder if the fpl hole can get gummed up and or blocked from oil used “too long” or will the oil pressure keep the hole open...?
This goes for other small bores, holes ect in the oil system... Q: Should a min and max bore/hole size be spec’d to prevent such? What is the bore/hole size for flp, cam spray bar, chosen case squirters, crankshaft, are the camshafts being drilled, what about the other oil passage/bores/holes sizes...? Q: what happens when the external oil thermostat opens to circulate oil to a front oil cooler...? Does the pressure drop to a level that jeopardizes the other oil areas? Just a point to consider as this research gets deeper and deeper... |
Need to find out how the new 2018 GT3 engines have this spec’d for reference... Jmho
http://forums.pelicanparts.com/uploa...1545230685.jpg Not seeing squirters here Credit to Doug/"2.7Racer" for posting this diagram. . |
Make sure you decide which route you want to go with the crank with respect to cross drilling and the #4 bearing. Some like to groove the bearing, some like to groove the crank. Marine chose to groove the crank in my instance.
Marine also removes all of the aluminum plugs and replaces them with steel set screws. This allows you to clean the crank before you install it (Marine specifically said they don't finish-clean it for liability reasons) and clean it in the future. Also make sure you enlarge the #4 main web oil feed hole in the engine case all the way back to the oil gallery. You need to enlarge this oil feed hole in order to ensure sufficient oil feeds the #4 main bearing because you're taking some oil away from that bearing and delivering it elsewhere. The whole purpose of the cross drilling is to provide a more direct path to the #2 and #5 rod journals via the #4 main oil feed and you don't want to starve the #4 bearing by "stealing" oil from it. In the original state, the crank has #2 and #5 rods as the last journals to get oil because the crank is fed from the ends and moves inward from there. You of course also need to enlarge the oil hole in the bearing shell too!! Here's a nice topic on the cross drilling and I made a crude image/map to show how the oil moves in and out of the crank http://forums.pelicanparts.com/911-engine-rebuilding-forum/582197-another-crank-cross-drill-question.html The oiling holes in the FPL rods are relatively large. If one of those holes gets clogged up, you've got much bigger problems going on and the engine is well on its way to being damaged. For reference, the smallest oiling hole in the engine is the camshaft/rocker/valve spring spray bar and it is literally a pinhole size. If you're going to change squirters, Catorce here on the forums has manufactured a nice serviceable squirter. https://taormina-racing.myshopify.com/ The squirters are not shown in that diagram you posted because the way they're fed oil is a little bit complicated. Here's a clearer three dimensional image and it still doesn't show the squirters. This image may be too early, before the squirters were introduced http://forums.pelicanparts.com/uploa...1545244164.jpg The squirters receive oil via the main oil gallery by intersecting some of the main bearing oil passages. Some also intersect the case through-bolt bores! Incidentally last month a forum member asked me about the through bolt holes (which holes see oil pressure) and I had to take a look at one of my cases to refresh my memory. So I decided to make a sketch that to identifies which through bolt holes receive oil and what they're connected to. Basically all of the lower through-bolt holes are "dry" except for one. http://forums.pelicanparts.com/uploa...1545244351.jpg http://forums.pelicanparts.com/uploa...1545244396.jpg |
nice Kevin... MEGA IMPORTANT info you shared here on oil system...
The crank and rods in a 3.2 are totally up to spec for a naturally aspirated engine. I would have a machine shop blueprint the stock engine to perfect stock tolerances, rebuild with Mahle pistons, and Porsche brand engine bearings. If I really wanted to invest, I would consider having an ATI damper made for the engine, and call it a day. There is no return on investment on the other items if you aren't building for power. What are the normal failure modes for a 3.2 Carrera? Valve guide wear, Piston / cylinder wear, broken head studs, cam chains / tensioners, rocker shaft leaks. Improvements in those areas might be a win... but you certainly do not need to be looking at crank work and rods. You're more likely to introduce a stress riser than to achieve anything meaningful.
Some people just like to throw money away :confused: |
If I can give some additional advice, maybe go about this in a more analytical manner. You can calculate the theoretical horsepower the engine should make from the calorific value of the fuel used. Then you calculate all of the MEP's, pumping losses, frictional losses, etc. What you should then work on, are the HP numbers between the ideal and the actual. You will soon see where you need to give the most attention too. |
Your do notes: Decide on cross-drillYour warnings: If rod's FPL gets clogged, engine's on way to damage (My note: Plan is not to eliminate standard lubrication for pin. FPL is addition.Your parts input: Rebuildable squirter - Taormina offers standard and oversizeYour visual ref: http://forums.pelicanparts.com/uploa...1545313576.jpg http://forums.pelicanparts.com/uploa...1545313576.jpg http://forums.pelicanparts.com/uploa...1545313576.jpg Idea of easy access into crank... is that because you're in there quite often? Quote:
ATI dampening is a great example of WTF this thread is about. Something new, at least for me. If this adds to engine's happiness, and I suspect it does from quick research I've just done, by default it's a consideration for incorporating. Thanks for input! Quote:
Appreciate your analytical approach Neil... oddly perhaps, +++HP is notably NOT a requisite for this build. Taking 3.2 platform and making engine operate smoother is. Whatever HP gains are had from this are a bonus. Journey taken here is to uncover opportunities (left on table by Porsche) to improve engine's durability and operating performance. In no way am I critical of 3.2 in stock form. It's a great engine AS IS imho! (My premise: Porsche---any manufacturer that wants to be profitable---can only go so far with product creation based on price point their selling their product at. By default, there's usually room for improvement. It's a time & money limit equasion.) . |
Anyone experienced with Brisk or NKG surface gap plugs?
http://forums.pelicanparts.com/uploa...1545490075.jpg http://forums.pelicanparts.com/uploa...1545490075.jpg |
Mike Bruns could tell you about those surface gap plugs. I recall he used a somewhat similar plug (Champion C57A) in a forum member's engine.
Check Gertvr's build here and some of his other threads. http://forums.pelicanparts.com/911-engine-rebuilding-forum/455503-gert-s-engine-rebuild-upgrade-chasing-300hp-yes-another-one-sorry.html Gert did some really good work in building/designing his engine and the dyno results proved it. Regarding the crank plugs, I think Marine does it just for ease of cleaning in the future. Sure the customer can easily clean it when it's returned back from service w/out the original style of plug in place. But then you have to tap new plugs in place. In terms of future cleaning, the original aluminum plugs are pressed in and therefore require you to drill and tap them to pull them out. With the steel set screws, you use thread locking compound to retain them and they are easy to remove in the future with a hex key. Clean the threads with an appropriate thread chaser, clean out any threadlocker remnants, reinstall set screws. I myself didn't expect that I would be in there often cleaning it. My engine was intended to be a mild build and last a lot of hours, not requiring frequent refreshing. The threaded crank plugs is a nice feature Marine provides if you request it and I don't recall it being an expensive service either. |
Gert, if you happen to read this... fine work on your build. Am posting your end-specs for ref. Thanks for detailed documentary you posted. Here Goes:While Gert's build hunted HP for his racing interests, I think there's applicable aspects for an endurance build (as is my interest.) My status... am still tweaking plan/budget but almost ready to get on with it. Last major hurdle... sorting out work space. I've looked into local derelict warehouse space in Miami's downtown. Very convenient---can take train, bike or even walk... great location! Security is generally terrible. Risk of walking in to no engine & tools... very tangible. Passing on that plan. Another idea is to rent 20 x 8 x 8 storage pod/container. Am still stuck with needing space to land it for a few months. Am eager to solve this puzzle as it'd be nice to get on with this while cool temps exist. Will visit a few places tomorrow in this regard. |
Karl,
It's Ok to disagree. Maybe I have misunderstood what you are trying to achieve. But there seems to be some odd ideas mixed in with some good ones. The idea of pin oiling up through the rod beam is a good one, but it is done typically for some specific reasons. One is, the pin does not run in a bushing and or the pin shows signs of galling. In your case I see it doing nothing, but costing you a lot more money. Normally, before this is done, the clearance between the pin and bushing is increased, the pin OD and or wall thickness is increased, if the pin was bending. Will it help lubricate the pin better, sure it will, but will it lower any friction with the added oiling. If there is no issue with galling now, I suspect almost zero change. DLC the pins will help here. You have also asked about using surface gap spark plugs. Again, it seems you have found these to be an attractive choice because they maybe different, but understand their use too. Typically, they are used in highly boosted engines with very close piston to plug clearances. In a 2V Porsche engine with huge chamber volumes and cantered plugs, they should be last choice of plug to use. These also run the coldest with the center electrode pulled all the way back into the shell. It takes a lot of energy to fire these compared to a standard firing end plug, and the throttle response always suffers with these plugs. They are designed for a specific use and your application is probably not it. My suggestion to take a more analytical approach, is one that will show you where to focus your attention. Not just about torque production, but where you can raise the efficiencies lost in just turning the engine over. You can separate all the losses into their own categories and soon see where you are losing power. It’s an easy mathematical exercise to calculate the HP the fuel used can produce. This is where the chemical potential turns into a theorical mechanical HP number. Now you can subtract all the losses and come up with what the actual “net” performance could be. I won’t use the actual numbers here (don't know your fuel type etc,) but will use some plug numbers to give you some idea of what I am suggesting. These engines are not the best engines for efficiency either. They make approximately 30% of what their total efficiency could be due to old age and design. Consider your engine as 6 individual cylinders. I know for sure that these engines, street or the most modified race version do not produce the same torque in each cylinder. This is due to maldistribution in the Intake system, thermal issues with the #2 and #5 cylinders “siamesed” between the other end cylinders, among many other factors. These engines have a distributor typically and the spark timing is adjusted and sent to each cylinder at the same crankshaft degree. This is what can be said to be, global timing. In your case unless you are using some sort of individual Ignition timing per cylinder, say your total timing advance may be set at 32 degrees. But the end cylinders may make their peak power at 28 degrees. Not every cylinder will make its best torque at 32 degrees. So here is your first loss of performance. Should you stick with the distributor or go with some sort of EFI system? You are not hot rodding your engine here, just making it more efficient. Is this not the task at hand? But you will need to measure the cylinder pressure in each cylinder at a measured crank angle and calculate the torque based upon the pressure and subtract 1/6 of the frictional losses to obtain net brake torque for each cylinder. Costly and probably well outside the DIY person's ability. So your choice maybe to stick with the distributor. You get my reasoning here. It’s a slow process, one based on the engine and your ability to pay. The same can be said and considered for the air fuel ratio. Lets say these engines will make their best power at 12.5 AFR. But with poor manifold air distribution, some cylinders may run leaner or richer. Also, these air-cooled engines will run higher head temperatures when run closer to 14.7. numbers. They need to run richer typically to run cooler. This changes the maldistribution numbers even further. So together the individual cylinder losses due to the ignition and fueling could be costing you upwards of "20" HP. We have measured this on engines we have produced, but this number will change based on the individual engine and its parts. This could be a good reason to run EFI with individual spark and fuel timing. You could achieve a better burn in each cylinder and gain back some of the 20 HP. Consider, if the best cylinder was to make 55 HP and the others were less with some around 45 HP and your engine makes 275 BHP, if you were to gain back 10 HP per the other 5 cylinders, your engine now makes another 50 HP. Maybe look at these losses. At least understand them. Where are your losses and where can you gain back the lost performance. These can be separated into different ("non") efficiencies. These are the standard ones known as Thermal, Volumetric, and Mechanical efficiencies. Do some research and find out what each one is about, what each one is comprised of and their individual contributors. Here’s a very simple break down. Thermal can include things like the engine’s compression ratio, cylinder head design, spark plug placement and type, any heat losses etc. Volumetric is all about the engines ability to pump air efficiently, the Intake manifolding, the exhaust system and the camshaft parts. Mechanical is frictional losses, any distortion in the cylinders and pistons, how round the pistons stay, the finish on the cylinders and ring tension, component weight, oil viscosity, coatings, etc. So here are some areas to look at. What can you do within your budget to gain back some of these losses? Knowing where the losses occur is a huge start. If you calculate the potential HP the fuel could produce you may find a theoretical number well above 1500HP. The inherent losses of the 4-cycle 2V air cooled Porsche engine could be as much as 800 HP or more. Say your engine makes 275BHP on the dyno. The difference between the actual and the theorical is now 425 HP. This is the power you lose just running the engine. This is the number you should focus on to make the engine more efficient. In the areas I have suggested, maybe you can gain back 10 HP in each, netting a gain of 30 HP. Now your engine makes 305 BHP. These are plug numbers and not to be assumed as real. They are to use as an example of how you could look at your project in a more analytical manner. There is a lot more to each and way more detailed information that should be used and considered, but this gives you an idea of how to go about this. We often see as little as ˝ ft/lbs gain but added with all of the ˝ ft/lbs we can gain with a total of 15 ft/lbs and at the maximum RPM used this can result in a good HP gain. I hope this has not bored you and has given you some areas to look at. Don’t get caught up in the latest craze unless you can measure and calculate a reason to do it. Don’t forget that good assembly procedures are extremely important as well. All of this is useless unless the engine is assembled correctly. |
There is a plan to incorporate EFI and EDIS. Am now wondering if individual cylinder timing can be controlled? And how to determine what the individual timing settings should be? I do not plan to go with individual throttle bodies but that seems a more interesting direction than it did a while ago. Am amazed that with all the material sciences and technology available that engines loose so much energy just running. No boredom here Neil. Your comments were read a few times with zest. Am moving forward with new perspectives & clarity. Thank you for this input! |
Spoke with Carillo re forced pin lubrication. Cost per rod bore is $90. There's value in terms of added lubrication but downside for this particular build---which seeks to reduce reciprocating and rotating masses---rods would need to have mass added in order to accommodate bore. Richard estimated 25-30 grams per custom rod.
Thought about it and am going with weight reduction rather than forced pin lubrication. . |
