JoeMag's Avatar
Bolts -- where to buy with factory type coating/plating
Where can I buy metric bolts that have the plating like the factory?
For my axles I used some that were standard zinc plating and they were a bear to get out. They'd stick and really be hard to break loose. Went back to factory ones and they break loose very smoothly.
I recently went to California Motorsport Diff cover and needed different length bolts (don't recall if shorter or longer). In any case, replaced with standard zinc plated ones and they also "stuck". Everyone one "popped" when breaking loose to remove.
Where can I get bolts that have a factory like plating/coating?
Old 12-11-2018, 10:29 AM
Mike Billings's Avatar
I like EBS racing for this. Enquire by email or phone.
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 12-11-2018, 12:14 PM
Under the radar
Trackrash's Avatar
My axle bolts are not plated. Usually the high strenght bolts, 12.9, will be unplated. That said, I have never experienced bolts sticking due to zinc plating. Most guys have trouble with them coming loose...
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-11-2018, 03:32 PM
My bags of axle bolts and clutch bolts are just flat black with 12.9 markings
Bruce
Old 12-11-2018, 04:34 PM
safe's Avatar
Bruce
Yes, I don't think you can plate a 12.9 bolt without loosing the "12.9" hardness.
Magnus
Old 12-12-2018, 04:20 AM
The plating controls corrosion. Use anti-seize to lube the threads. Increases torque accuracy; prevents electrolysis and corrosion.
Sherwood
Old 12-13-2018, 04:52 PM
AskewRSR's Avatar
We buy in Bulk from https://www.belmetric.com/
1965 911 Vin 1249 Slate Grey
1969 911 Golden Green 2.0 Twin Plug
1971 911 S Gold Metallic. Peter Gregg
1974 911 RS Euro Metallic Blue Gold lettering
1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor
Old 12-14-2018, 10:16 AM
Strygaldwir's Avatar
I don't think there is any magic about Porsche bolts! I bought Porsche exhaust head studs from the dealer about 14 years ago. Would you believe they rusted, again!? Didn't have to have them drilled out this time, thank goodness. Replaced them with ARP studs, the head ones didn't rust, so they must have a better solution! I'll check them in 10 or so years to see ;-).
Old 12-24-2018, 09:40 AM
