boxer246's Avatar
Crankshaft ID
Can someone help me identify this crankshaft please? An acquaintance owns it and I was thinking of taking it off his hands if it’s what I need...he thinks it’s a 2.2 crank, it’s obviously a counterweighted one. But that’s all I know. Journals have some rust spots so I don’t know if it’s worth messing with, but anyway I’d like to at least ID it.
Here’s a couple photos. Sorry for the poor quality, and I didn’t snap a pic of the whole crank. But he lives close so if I need to I can:
Old 12-11-2018, 07:24 AM
Under the radar
Trackrash's Avatar
Probably a 2,2 crank. Mic the journals. That will tell you everything you need to know.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-11-2018, 03:48 PM
2.2 all journals are the same size. Yes he drill holes for rod oil are the same. Size as plugs
2.4 the rod throws are smaller. The drill holes for the rods are larger than the plugs
Bruce
Old 12-11-2018, 04:28 PM
boxer246's Avatar
Ok, thanks for the info guys.
So, the question as to weather or not this crank is worth fixing...if it needs both the mains and rod journals ground undersized....is this a good idea? I’ve read various viewpoints here and there on this. If I remember correctly, I read that one of the problems with an undersized crank is that the corresponding oversized bearings needed are prohibitively expensive?
Old 12-12-2018, 05:53 AM
Check the price and availability of the bearings you will need
It might be less to have the crank fixed than cut
Bruce
Old 12-12-2018, 12:06 PM
boxer246's Avatar
Bruce, can you explain what you mean by having the crank fixed or cut?
For clarification on my end, I have a 2.2T motor, that when I do the rebuild I was planning to use a CW crank such as this one instead of my non-CW one.
Old 12-12-2018, 12:58 PM
Under the radar
Trackrash's Avatar
A lot of guys prefer the non counter weighted crank. Lighter and quicker response.
However, if you plan on spending most of your time above 6000 RPM the fully counter weighted shaft is the way to go.
Gordon
Old 12-12-2018, 01:48 PM
There is a few people in the country who repair cranks to standard/std
Bruce
Old 12-12-2018, 05:25 PM
boxer246's Avatar
Ok I understand. No doubt a more expensive process than simply grinding and polishing undersized.
Trackrash thanks for your comments....I have also heard this before, that there is some affinity for the T crank. And no, I’m not planning to spend much time above 6k...the plan is just a nice little street motor.
Old 12-13-2018, 06:01 AM
The fix
May be less than the price and availability of the bearings
Bruce
Old 12-13-2018, 04:14 PM
