Here are some updates.......engine coming together.......going to dyno soon........http://forums.pelicanparts.com/uploa...1554949580.jpg
http://forums.pelicanparts.com/uploa...1554949580.jpg http://forums.pelicanparts.com/uploa...1554949580.jpg http://forums.pelicanparts.com/uploa...1554949580.jpg http://forums.pelicanparts.com/uploa...1554949580.jpg |
Really nice - I wish my engine builder took note in terms of pics and updates; it appeared to
Be a chore to him to let his customer know what was going on... I’ve not seen those pistons before, nice option |
Sure do enjoy Steven's tools.:cool:
Just curious... I don't see any locking tabs on the oil pump nuts? :confused: |
I decided to stay single plug with the same 3.4 Mahle Max Moritz design 9.8 compression P&C (my 3.2 pistons had valve slap on them and were alusil). But also going with 964 cams, Aasco springs and retainters for higher redline. BTW... REALLY love these pics. I wish someone would just create a video of EVERYTHING they do to build the engine. |
https://m.youtube.com/watch?v=HqTJ2lgVEKY, if the link doesn’t work search “The Canary Files” this guys documented his entire engine rebuild on YouTube I’ll be doing the same when I rebuild my 964 engine later this year when I finally get my garage built |
Trackrat - The legendary Carroll Smith believed locking tabs don't work. He suggested "prevailing torque" nuts. I suspect nylocs, though less positive, would do.
I'd have to look at the other case half to be sure, but maybe the nut couldn't come all the way off anyway when the case is together? Only the upper nut is subject to tension with the pump turning. The force would vary with RPM, which is a minus for the nut staying put, but maybe not really enough to loosen a properly torqued regular nut? One doesn't hear about these nuts coming loose, though. |
What do you think Smith thinks about the ability of a wave washer to add anything significant to the stretch of a fastener? To be sure, Porsche used them in some applications, like under all those nuts holding the cam carrier onto the heads.
Loctite maybe, though if Smith is right about the tabs, with the standard torque for an 8mm stud, maybe any flat washer is fine with a standard nut. The washer keeps the nut from gouging the aluminum of the pump. |
Cross threading....
"Cross threading is almost as good as Locktight"
Anon |
Amazing thread ..... :eek::eek::eek::eek::eek:
Well done! Great photographic detail.
what size/part number are those Bosch spark plugs you're using there sir
Nuts in that picture of the oil pump installed are actually nyloc style like those used on the valve covers. Like Walt said, the "top-lock" prevailing torque nuts are a better choice here. Nyloc don't provide a lot of locking effect
Interesting choice to use nylocks inside the motor. Porsche never did that, and there are mechanics that recommend against it. Loctite would probably do the trick. How can locking tabs fail anyway?
Gordon,
The locking tabs don't fail in terms of breakage. But if the forces are high enough, they can release the fastener. I doubt this could happen to the oil pump since it's not under a lot of stress. But I have seen ring gear bolts back out http://forums.pelicanparts.com/uploa...1555942397.jpg http://forums.pelicanparts.com/uploa...1555942409.jpg The above diff was from a '79 915 trans run very low on oil. Apparently the heat & stress on the ring gear caused the bolts to back their way out. Looks like the flats of the bolts pushed past the bent ends of the locking plates. I recently took a ring gear off of a LSD and the tabs are fairly sturdy metal. It takes quite a bit of force with a hammer and punch to maul the locking plates off the bolt heads. |
